  3. Maintain display list on window
  • Subscribers 150
  • Views 8570
RicardoGV1
RicardoGV1 over 3 years ago
Hi everyone,
I'm using the dlAttachDlistToWindow to draw on window, but I'm struggling with two things, this only render one time and if I move the mouse or pan the image disappear.
and when I draw something, the layout disappear.
For the erase stuff the closes thing I found is dlSetClearOnDraw but don't prevent that.
For the disappearing problem, I was thinking about using loops to keep the drawing but is not the optimal solution.
is there any extra documentation about this apart from the Cadence User Interface SKILL Reference ICADVM20.1?
/* First, make the DisplayList. */
dl = dlMakeDisplayList( )
/* Now make a pen table for it. */
penTable = dlMakePenTable(5)
/* Assign the penTable to the display list. */
dlSetPenTable( dl penTable)
/* Define a couple of colors. */
colorIndex = hiStringToIcon( nameToColor( "blue"))
dlSetPenColor( 1 colorIndex penTable)
/* Set this pen "filled." */
dlSetPenFillStyle( 1 "SolidFill" penTable)
/* Put the objects in. */
dlAddBox( dl 1 0:0 100:100)
dlAddBox( dl 2 10:10 90:90)
dlAddCircle( dl 3 50:50 20)
dlAddStrokeText( dl 4 50:50 "Window" "0" "gothic" 20 "center")
/* Make a window. Put the DisplayList into the window */
/* and set the windows icon. */
w = hiGetCurrentWindow()
;dlSetClearOnDraw(dl w)
dlAttachDlistToWindow( dl w)
best regards,
R.Gómez
  • AurelBuche
    AurelBuche over 3 years ago +1
    Hi, I believe what you are trying to do is not feasible using display lists Display lists are not meant to be drawn inside a layout window, the doc is quite clear about the window argument: …
  • AurelBuche
    w_windowId
    ID number of an empty window. It cannot be the window of another application.
    If you want to add graphical hints on top of a layout view you might want to have a look to highlight set functions instead
    Hope this helps,
    Cheers,
    Aurélien
  • RicardoGV1
    RicardoGV1 over 3 years ago in reply to AurelBuche
    Thanks Aurélien
