  3. Creating a GUI window like TREE command
  • Subscribers 150
  • Views 9609
Tejaskill
Tejaskill over 3 years ago
Hi all,
I am looking for a code which can create a GUI window same as leHiTree command creates
And that window should display the user input strings
Can anyone help me
Thanks in advance,
Teja.
    Teja,
    This is rather an ambiguous request. You want to "create a GUI window same as leHiTree". Does that mean?
    1. You want a form like this:
    2. You want a result window like this (with the same content but some additional data):
    3. Or you just want a text window similar to that which is produced by the tree command but with completely different contents?
    If it's the first two, you could adapt this code: How to print a hierarchy tree of a config-based schematic, normal schematic, or layout view (which I originally wrote before the schematic editor had a tree command as standard). If it's the third, you could either write to a file and then use the view() function to display the file, or you could just use:
    win=hiOpenWindow(?type "text")
    hiTextDisplayString(win "Hello\n" nil)
    hiTextDisplayString(win "World\n" nil)
    or something like that.
  • Tejaskill
    Tejaskill over 3 years ago in reply to Andrew Beckett
    Hi andrew,
    Thanks for the reply I originally wanted the third one.
    I have written the code based on your inputs
    But I also wanted to add File, Edit, View buttons to menu bar.
    could you please suggest a solution.
    Teja.
    Andrew Beckett over 3 years ago in reply to Tejaskill
    Teja,
    You could do instead:
    win=view("/dev/null")
    hiSetWindowName(win "Viewfile")
    The view() function returns a text window looking at a file, and if we don't care about the file part we can give it a null file - and then write to the window as before. Or if you have a real file, you could use that. The view() function will add the menus you're expecting.
