  3. How to extend PVS DRC Debug window Menu with Re-Run opt...
  • Views 8293
How to extend PVS DRC Debug window Menu with Re-Run option
Laurentz
Laurentz over 3 years ago
Hi all,
I am using PVS  DRC 19.12 and I would like to extend the PVD DRC Debug Menu to have the possibility to re-run the DRC Check with the same settings like the last Run.
This Menu is already there in PVS LVS Debug, like in the picture.
How can we do this ?!
Thank you & regards,
    I don't think you can customise the UI - of either the DRC Debug Environment or PVS Results Viewer (not sure which you're using). However, the window that appears when you run PVS DRC already has a "Resubmit" button.
    Please contact customer support (create a support case) as that's going to be the best way to handle any enhancement that might be needed.
