  3. getting error when using env variable in xstremout
  • Views 9362
saurabh96
saurabh96 over 3 years ago
Am getting error when using env varaible to xstremout the _oa_gds.objectmap
i have set env as setenv CADENCE_PDK /home/test1/xyz
so when am giving layermapfile=$CADENCE_PDK/cadence_oa/test/maps/test_oa_gds.map
am getting error as ERROR (XSTRM-153): Failed to open object map file '$CADENCE_PDK/cadence_oa/test/maps/test_oa_gds.map'. Check that the file exists in the run directory and that you have permission to read it.
INFO (XSTRM-273): Translation failed. '1' error(s) and '0' warning(s) found.
i have check n ciw env is set correctly and file exist also.
now when am using absolute path as layermapfile=/home/test1/xyz/cadence_oa/test/maps/test_oa_gds.map
its working fine in XStrem Out
can you help what the issue how to correct it
    Andrew Beckett over 3 years ago in reply to saurabh96 +1
    OK, so now you're asking a completely different question which is nothing to do with stream out. No wonder it's confusing. For your latest question, simply change: CSVport = infile( csvfilename ) …
    Your post is extremely confused because it's talking about object map and layer maps - the error is related to object maps, yet you mention layermapfile=... (there is no setting called "layermapfile" for strmout - it's layerMap. And anyway the message talks about object maps!
    I have tested strmout from both the user interface and the command line with a templateFile - and both support environment variables. I found an old issue where it didn't work before but that was fixed some time ago, in IC617 ISR16.
    Since you didn't mention the version you're using, didn't say how you're invoking the stream out interface (from the form or from the command line), how you are passing these paths with environment variables to the stream out process (template file or command line or UI field), and also were rather vague about whether this was an object map or layer map, it's rather hard to help. Clear questions tend to lead to clear answers.
  • saurabh96
    saurabh96 over 3 years ago in reply to Andrew Beckett
    sorry andrew, for confusion, let me be stright and explain in simple way-
    i have csv file in which is have defined
    test_file = $CADENCE_HOME/testfile.txt
    also $CADENCE_HOME is env var
    if i do get getShellEnvVar("CADENCE_HOME") Iin CIW i will get absolute path i.e /abc/xyz
    now i have another skill file in which i am reading the csv file and the test_file path
    but when am giviing test_file = $CADENCE_HOME/testfile.txt in csv its not working
    but when am defined test_file = /abc/xyz/testfile.txt in csv its working fine.
    am thinking to use eval function
    can you please guide whats wrong and how to correct.
    beow is some part of code-
    procedure( extractCSV(csvfilename)
    indexcount=0
    indexstring = sprintf(nil "%L" indexcount)
    cvoptions = list(nil)
    cvoptions1 = list(nil)
    layerMapFile=nil
    objectMapFile=nil
    techLib=nil
    incFile=nil
    process=nil
    ams_path=nil
    lsfQueue=nil
    while( gets(myline CSVport)
    ;new cell view
    ;printf("--%L\n" myline)
    mylist1 = parseString( myline "=")
    varName = nth(0 mylist1)
    filePath = nth(1 mylist1)
    when( length(mylist1) == 2 && !rexMatchp( "#" car(mylist1)) && !rexMatchp( "//" car(mylist1))
    && varName == "test_file"
    rexCompile("\"")
    filePath = rexReplace(filePath "" 0)
    inFileContent=infile(filePath)
    printf("****************************\n")
    printf("Reading included file: %s" filePath)
    to
    CSVport = infile( simplifyFilename(csvfilename) )
    simplifyFilename will do the environment variable expansion.
  • saurabh96
    Thanks a lot Andrew!!!!!!
