  3. Via conversion using leReplace command
  • Subscribers 150
  • Views 9339
Tejaskill
Tejaskill over 3 years ago
Hi all,
I am able to replace via using leReplace command as follows
leReplace(geGetEditCellView() geGetSelSet() list(list("via definition" "==" "M2_M1")))
But I am unable to change the via cut Width, Length, Row spacing, Column spacing using the following,
leReplace(cv via list(list("via definition" "==" "M2_M1") list("cut Width" "==" 0.2) list("cut Length" "==" 0.2)))
Can anyone suggest me a solution
Teja.
    As you can see on the Find/Replace form, it should be "width" and "length", not "cut Width" and "cut Length":
    leReplace(cv viaList list(list("via definition" "==" "M2_M1") list("width" "==" 0.2) list("length" "==" 0.2)))
  • Tejaskill
    Tejaskill over 3 years ago in reply to Andrew Beckett
    Thanks for the reply Andrew
    It works fine now
    But I have to get the database id of the newly created via, is there any way for that.
    Teja.
    Andrew Beckett over 3 years ago in reply to Tejaskill
    This isn't entirely trivial because the leReplace function doesn't return the new objects. If you'd use the underlying database functions to recreate the via, then it would have been possible, but if using the simpler leReplace approach, then you could do it this way:
    ; create a unique (hopefully) fig group to hold the vias you're going to replace (this uses the time to make a unique name)
    fg=dbCreateFigGroup(cv lsprintf("vias%d" stringToTime(getCurrentTime())) nil 0:0 "R0")
    foreach(via viaList dbAddFigToFigGroup(fg via))
    ; now do the replace
    leReplace(cv viaList list(list("via definition" "==" "M3_M2") list("width" "==" 0.2) list("length" "==" 0.2)))
    ; the good news is that the fig group will hold the new vias:
    newViaList=fg~>figs
    ; we can remove the temporary fig group
    dbDeleteObject(fg)
    A little bit of a trick, but it seems to work!
