  3. How to modify content of a config and regenerate netlist...
  • Views 9727
How to modify content of a config and regenerate netlist view in skill
Ali Bastami
Ali Bastami over 3 years ago
This topic may already have been discussed and solved, if so, could I get a link
I would like to use skill commands to modify the content in a config view (change a cell view) and regenerate a netlist.
I know that I can use the following command to regenerate a netlist based on an existing config vew:
simulator( 'spectre )
design( "libname" "cellname" "viewname")
createNetlist( ?recreateAll t)
But what are the prior steps to manipulate and modify the content of the config view?
    See this previous post.
  • Ali Bastami
    Ali Bastami over 3 years ago in reply to Andrew Beckett
    Thank you for your response.
    do you have an example of the skill code on how to change a view in the config view?
    example : if I have a defined config view : design("libname" "cellname" "config")
    And I would like to change the view for cell 1 from schematic to extracted. in the hierarchy.
    and recreate a netlist based on the new hierarchy view
    How would the skill code be like?
    Andrew Beckett over 3 years ago in reply to Ali Bastami
    hdb=hdbOpen("libname" "cellname" "config" "a")
    hdbSetObjBindRule(hdb list(list("libname" "cell1" nil nil)) list('hdbcBindingRule list(nil nil "extracted")))
    hdbSave(hdb)
    hdbClose(hdb)
    This is assuming that cell1 is also in the library libname (you can change the second line as you see fit).
