  3. get string variable value in an Ocean post-script
  • Views 8584
Quentin S
Quentin S over 3 years ago
I'm running simulations with Assembler and using an Ocean PostScript to compute my outpus.
For this I need to access some variables inside the database.
For some of them that are reals or integer, no issue. I can use the VAR fonction that will read the variable_file (I think) and get me the corresponding value.
For others, which are strings. I'm not able to get them and I can't even see them in the variable_file in the results DB. The only file in wich I can see them is the log file :
Setting var Signal_file = "\"sources_smearing_maxSwing_center_40_lines-3.cir\""
Any idea on how to get the value of this string variable ?
Quentin
    Quentin,
    You should just be able to use VAR("Signal_file") in your OCEAN measurement script. I thought initially that you need to ensure that the designParamVals info database is saved from Outputs->Save All (in the Save circuit information analysis section), but it works even if that's not saved.
