  3. How should I use skill code to get the mapping between instanceName...
  • Views 8081
How should I use skill code to get the mapping between instanceName and its terminalName and netName
xingz311
xingz311 over 3 years ago
return like:
map["I15<0>"]["is_500nA<4>"] = "is_500nA_VMC_C<2>"
sch:
  • AurelBuche
    AurelBuche over 3 years ago
    This seems like a simple problem to address but the answer is not as simple as it looks!
    I rewrote a code snippet from older scripts I had, if someone have a simpler solution please share it!
    Code is below, it is written in SKILL++ and defines only get_inst_term_net function to be used like :
    (get_inst_term_net (geGetEditCellView) "I15<0>" "is_500nA<4>")
    Hope this helps, don't hesitate to give feedback in case you face any issue or notice a bug
    Aurel
    browse_nets.ils
    (inScheme
    (let ((bus_pcre (pcreCompile "(\\w+)<(\\d+)>")))
      (defun parse_name_with_bit (name_with_bit "t")
        "Return separated name and bit from NAME_WITH_BIT"
        (assert (pcreMatchp bus_pcre name_with_bit) "Unable to find name and bit in %s" name_with_bit)
        (list (pcreSubstitute "\\1") (atoi (pcreSubstitute "\\2"))))
      (defun get_term_by_name (inst name "dt")
        "Return INST terminal named NAME"
        (car (exists term inst->conns (pcreMatchp (strcat "^" name "<\\d+(:\\d+)?>$") term->name))))
      (defun find_mem_conn_by_name (inst term_name_with_bit "dt")
        "Return INST terminal and index associated to TERM_NAME_WITH_BIT"
        (destructuringBind (term_name term_bit) (or (parse_name_with_bit term_name_with_bit)
                                                    (error "Unable to find terminal %s in %A" term_name_with_bit inst->name))
          (letseq ((term  (get_term_by_name inst term_name))
                   (index (sub1 (lindex (dbProduceMemName term->name) term_name_with_bit)))
            (when index (list term index))
      (defglobalfun get_inst_term_net (cv inst_name_with_bit term_name_with_bit "dtt")
      "Return signal associated to INST_NAME_WITH_BIT TERM_NAME_WITH_BIT in CV
    Example (get_inst_term_net (geGetEditCellView) \"I<12>\" \"OUT<3>\") -> \"CONNECTED_NET\""
      ;; In this code, we differenciate bit and index:
      ;; - bit is given in name (i.e. in "I<12>" bit is 12)
      ;; - index is the bit position in bus
      ;;   (i.e. in "I<27:12>" bit 27 is at index 0,
      ;;   bit 12 at index 15 and bit 20 at index 7)
      ;; Find instance index, it is given directly by `dbFindMemInstByName'
      (destructuringBind (inst inst_index) (or (dbFindMemInstByName cv inst_name_with_bit)
                                               (error "Unable to find instance %s in %s/%s/%s"
                                                      inst_name_with_bit cv->libName cv->cellName cv->viewName))
        ;; Find term bit
        (destructuringBind (term term_index) (or (find_mem_conn_by_name inst term_name_with_bit)
                                                 (error "Unable to find terminal %s in instance %s in %s/%s/%s"
                                                        term_name_with_bit inst_name_with_bit cv->libName cv->cellName cv->viewName))
          (let ((signal_index (dbGetNameNumBit term->name)*inst_index + term_index))
            (nth signal_index term->net->signals)->name
      )); Scheme closure
    ;(get_inst_term_net (geGetEditCellView) "DUT<20>" "OUT<1>")
