  3. placement of multiple elements using a file that contains...
  • Views 8514
placement of multiple elements using a file that contains the coordinates
ArantxaU
ArantxaU over 3 years ago
Dear all,
We want to create an array of devices  using a file that contains the positions of  all the devices ( around 1000 elements). How can we proceed to place it using a skill tool?
We are using cadence IC6.1.7
Best regards
  • ArantxaU
    ArantxaU over 3 years ago in reply to AurelBuche +1
    Dear Aurelien Thanks a lot for your help. It works quite well Regards Arantxa
  • AurelBuche
    AurelBuche over 3 years ago
    Hi, without any example of what your file contain it is complicated to make an accurate answer...
    The skeleton of the script will be :
    ;; Open master of instances to create and coordinates file
    (let ((master (dbOpenCellViewByType library cell view))
          (port (infile file))
    (cv (geGetEditCellView))
    coords)
      ;; Supposing each line contains a pair of coordinates, browse them
      (while (setq coords (lineread port))
      (when (listp coords)
    (dbCreateInstance cv master nil coords "R0")
    );when
    );while
    ;; Close master and port
    (dbClose master)
    (close port)
    );let
    The code obviously needs more checks (at least for lineread output) but this should be a good start
    Depending of how your coordinates are written, you might want to shape lineread output to make it a pair of coordinates
    Note that for now it works in current cellview
    Cheers
    Aurelien
  • ArantxaU
    Dear Aurelien
    Regards
    Arantxa
