  3. How to add a iopin in Square shape? How to add nets from...
  • Replies 9
  • Views 11928
How to add a iopin in Square shape? How to add nets from skill to it?
Sandeep Kailasa
Sandeep Kailasa over 3 years ago
I need to add inputOutput pins in Symbol ,and also add a small net to it without making any connections to it.
pinMaster=dbOpenCellViewByType("basic" "actHiInp" "symbol")
schCreateSymbolPin( cv pinMaster "gnd" "inputOutput" 1.5:-.475 "MXR90" "" nil nil "ground" )
schCreateSymbolPin( cv pinMaster "vdd" "inputOutput" 1.5:0.375 "MYR90" "" nil nil "power" )
  • 1.)  I have used above functions to add iopin's from CIW . But the symbol is in round shape . How can I get the iopin symbol like below that got generated when we create a symbol view from schematic.
When I used schCreateSymbolPin function then I am getting this form of iopin symbol like below.
And this pin symbol is very small, I want to add a square pin symbol
  • 2.) After adding pins ,how to add a piece of net to it from skill code.
Please help me here as I am new to Skill.
Thanks in Advance!
    Use the "square" pin template instead of "actHi". Note that this doesn't come with a leg though.The available template are defined by the variable schSymbolPinMasters and can be seen interactively in the Create->Pin command in the symbol editor. You could always define your own template and update the variable (search in the Help menu in the box at the top of the menu for schSymbolPinMasters).
    I don't know what you mean by "how to add a piece of net to it from skill code". The connectivity information is already created when you use schCreateSymbolPin - there's nothing else to be done. I don't know what "a piece of net" means.
  • Sandeep Kailasa
    Sandeep Kailasa over 3 years ago in reply to Andrew Beckett
    Thanks Andrew,
    Yeah I checked in Symbol Editor to create a Square Pin, But it is generating a square share alone, how do i get it with net. And in which library can we find the square pins.
    I mean that , How can we add a net to the pin, no need to connect that pin to any other instance, I just want to add a net to it.
  • Sandeep Kailasa
    Sandeep Kailasa over 3 years ago in reply to Sandeep Kailasa
    This is the way the pin is getting added. How do i connect it Symbol and how to add a net to this pin?
    Andrew Beckett over 3 years ago in reply to Sandeep Kailasa
    You're using some strange terminology, I think. "how do I get it with net" - I assume you're taking about the green line (which is not a "net" but just part of the symbol graphics)?
    I have absolutely no idea what you're asking here. It makes no sense.
    Andrew Beckett over 3 years ago in reply to Andrew Beckett
    Looking a the schSymbolPinMasters variable:
    ((0.03125 32)
    ("square"
    ("input"
    ("basic" "sympin" "symbolNN")
    ("output"
    ("inputOutput"
    ... truncated...
    It's coming from the basic/sympin/symbolNN cellView.
  • Sandeep Kailasa
    Yeah I want to add that green line and also add a floating net to that pin
    You can add a green line two ways:
    1. Create your own template symbol (copy basic/sympin/symbolNN and then add a line to it in the symbol editor; then update the schSymbolPinMasters variable to add your new template to the standard pins)
    2. Create a line using dbCreateLine(cv list("device" "drawing") list(x1:y1 x2:y2)) where x1:y1 and x2:y2 are the coordinates of the ends of the green line to draw
    I have no idea what you mean by "add a floating net to that pin". What's a "floating net" on a symbol pin?
  • Sandeep Kailasa
    Thanks Andrew,
    This is what I mean by adding a net to the symbol.
    You wouldn't add a wire to the symbol - this makes no sense. You'd add wires in the schematic using an instance of the symbol.
