  3. sstatus command appears not to work
  • Views 8571
Sutlieff
Sutlieff over 3 years ago
I have an issue that seems opposite to a previous post I found in this forum.
The writeProtect setting in the status command is not having an effect
I have used the following in my CIW:
sstatus(writeProtect t)
t
The command appears to have been accepted.
Then I load some SKILL:
xxx= load("./myskill")
function abc redefined
function def redefined
Then repeat the command:
From the documentation, I expected to get an error:
*Error* def: function name is write protected
and cannot be redefined - abc
Can anyone see what I have done wrong?
Colin
    Colin,
    Do you have the SKILL debugger enabled? If status(debugMode) returns t, then write-protected functions may be overwritten. If you do sstatus(debugMode nil), you should see normal behaviour.
  • Sutlieff
    Thank you Andrew,
    I was, in fact, using the SKILL IDE to load the skill. The debug mode was set to "t"
    Thanks a lot.
    Colin
