  3. Standard I/O Ports Not Available in SKILL++ by Default
  • Subscribers 150
  • Views 2047
AaronSymko
AaronSymko over 3 years ago
Standard I/O ports (with the exception of poport) are not available in SKILL++ by default. It requires an importSkillVar to make them visible. Is this an oversight, or is there a good reason why this is so?
For example:
toplevel 'ils
poport
port:"*stdout*"
woport
*Error* eval: unbound variable - woport
importSkillVar woport
t
woport
port:"*ciwWarnPort*"
  • AurelBuche
    AurelBuche over 3 years ago
    I think they were not shared between the two namespaces by default (I am not even sure about poport, are you sure it's not any script in your setup that made the import?)
    I believe using importSkillVar as you do to make them global in SKILL++ is not really risky
    Anyway, on my side I created specific functions using inSkill to make sure I do not overlap any specific name (get_woport, set_woport, etc.)
    Andrew Beckett over 3 years ago in reply to AurelBuche
    poport and piport are imported automatically into SKILL++ as a small set of "required" global variables. This has been this way for a very long time (I didn't go back to check when - as far as I can see it's always been this way). I don't think it's an oversight to not include the others, but just done because you frequently would need at least some port to write to and read from.
