  3. How to create an attachmentList for a form
  • Views 8425
psill00
psill00 over 3 years ago
I want to create a attachmentList for a form with a loop
for( i 0 10
     attList = append1( attList stringToSymbol("hicLeftPercentSet | hicTopPercentSet | hicRightPercentSet | hicBottomPercentSet "))
hiCreateAppForm(?name 'custWhaaamoForm
?fields fieldList
?formTitle "Whaaamo"
?initialSize list(200 950)
?buttonLayout 'Empty
?attachmentList attList
Paul
  • psill00
    psill00 over 3 years ago in reply to Andrew Beckett +1
    Thanks for the info As for the stringToSymbol, goes to a basic law of the internet. To get the fastest and with the most response in anything, is to put post something wrong Paul
    Paul,
    Why are you using stringToSymbol? That's not going to work because it tries to create a symbol out of that big string (it won't evaluate it). Instead use:
    for( i 0 10
         attList = append1( attList hicLeftPercentSet | hicTopPercentSet | hicRightPercentSet | hicBottomPercentSet)
    or better still (since they're all the same) - use cons because it's more efficient than append1:
    for( i 0 10
         attList = cons( hicLeftPercentSet | hicTopPercentSet | hicRightPercentSet | hicBottomPercentSet  attList)
  • psill00
    Thanks for the info
    Paul
    Andrew Beckett over 3 years ago in reply to psill00
    Paul,
    That made me laugh!
    I also meant to mention that you should also look at using layout forms, as these are much more flexible than the old attachment-list way of making resizable forms.
