  3. Fetch Skill Script run directory inside a procedure
  • Subscribers 152
  • Views 9567
Shankar PA
Shankar PA over 3 years ago
Hi
I have a skill procedure/function defined inside a skill script(".il" file) that calls an external script(python).
This external script is placed relative to the folder in which the original skill script is located.
Currently I am hardcoding the absolute path of my external script. However I would like to reference the external script relatively.
I understand that outside a skill procedure
get_filename(piport)
would expand to the script name from which I can fetch the absolute path.
I would like to achieve the same thing inside a skill function/procedure. Is there any easy way to achieve this?
I did see an old thread on this type of requirement but couldn't get any directions.
Shankar
    Shankar, this post in that thread is the pertinent post.
    You could have:
    procedure(MyFunc()
      let((pathToMe dirPat dirPart)
        pathToMe=#.get_filename(piport)
        dirPat=pcreCompile("/[^/]*$")
        dirPart=pcreReplace(dirPat pathToMe "" 1)
        ;printf("dirPart=%L\n" dirPart)
        system(strcat(dirPart "/myScript.py"))
    The key is that the #.get_filename(piport) will get expanded and file loading time and if you pp(MyFunc) you'll see it contains the actual path embedded in the code.
  • Shankar PA
    Shankar PA over 3 years ago in reply to Andrew Beckett
    Hi Andrew
    Thanks for the explanation, This works for me.
    However, when I try to encrypt the skill file and load the encrypted version.
    #.get_filename(piport) gets expanded to "*ciwInPort*"
    Any workaround possible? My other alternative is to split the my main code into two files where I would keep the "path fetch" alone in an unencrypted procedure and keep the rest encrypted.
    Shankar
    Andrew Beckett over 3 years ago in reply to Shankar PA
    Shankar,
    That seems to be a limitation - it's expanded on the first read (when the file is read to encrypt it). I can't think of a way around it other than the approach you've suggested.
