  3. Display all nets Hierarchically per block
  • Replies 8
  • Views 12494
J P Cardoso
J P Cardoso over 3 years ago
I would like to display all the nets from the top of a design and down the hierarchy.
I've found an easy way of doing it, but it is very dumb. I am parsing the netlist and using the following commands:
deOpenCellView("lib_name" "cell_name" "schematic" "schematic" hiGetSessionWindow(hiGetCurrentWindow()) "r" )
geGetEditCellView()~>nets~>name
The approach above has two problems:
1 - It will open the cellview and I just want to "point" to that view, so the geGetEditCellView() gets the nets from the correct schematic
2 - I need a netlist. It would be nice, given the top, to dive into each block and then just do geGetEditCellView()~>nets~>name
Any help would be appreciated.
Thanks in advance.
Cheers,
Pedro
    Hi Pedro,
    Presumably you could do a recursive traversal of the schematic hierarchy (relatively simple if you can just use a switch view list) - I'm sure there are many examples of doing a recursive traversal. Something like this:
    procedure(CCFsimpleRecurse(cv @key
        (viewList "schematic symbol") (excludeLibs list("basic")) visited)
      let((master)
        unless(visited
          visited=makeTable('visited nil)
        foreach(instMaster cv~>instanceMasters
          unless(member(instMaster~>libName excludeLibs) || visited[instMaster]
            if(instMaster~>cellViewType=="schematicSymbol" then
              master=dbOpenCellViewByType(
                instMaster~>libName
                instMaster~>cellName
                viewList
            else
              master=nil
            visited[instMaster]=master
            when(master
              CCFsimpleRecurse(
                master
                ?viewList viewList
                ?excludeLibs excludeLibs
                ?visited visited
        visited
    procedure(CCFgetAllSchematics(cv @key
      let((visited withSch)
        visited=CCFsimpleRecurse(cv ?viewList viewList ?excludeLibs excludeLibs)
        withSch=setof(symbMaster visited visited[symbMaster])
        foreach(mapcar symbMaster withSch visited[symbMaster])
    Then you could start from the top level schematic and do:
    allSchematics=CCFgetAllSchematics(topCV)
    (you could open the topCV with dbOpenCellViewByType - no window needed).
    Then you have a list of all the schematic cellViews, so you could do a:
    foreach(cv allSchematics
      ; do something with each to get all nets - e.g. cv~>nets~>name
  • J P Cardoso
    J P Cardoso over 3 years ago in reply to Andrew Beckett
    Thanks Andrew.
    But how do I pass topCV (I mean the syntax)? I've tried this without success: topCV = hiGetCurrentWindow() .
    Kind regards,
    Pedro
    Andrew Beckett over 3 years ago in reply to J P Cardoso
    If the top cellview is open in a window, use topCV=geGetEditCellView() . hiGetCurrentWindow() returns the window identifier, not the cellView (please read the documentation for these functions). If you don't want to open in a window, you can use:
    topCV=dbOpenCellViewByType("topLib" "topCell" "topView")
    to open the database in SKILL.
  • J P Cardoso
    I am sorry, but it is not working for me.
    From the CIW:
    topCV=dbOpenCellViewByType("pedro" "tb" "schematic")
    db:0x3e4ca01a
    (db:0x423e611a db:0x3b7e2b9a db:0x3e4c299a db:0x3e4cd49a db:0x3e4c8f9a
    db:0x3e4c691a db:0x3e4cd49a
    cv~>nets~>name
    Kind regards,
    Pedro
    Your foreach loop is not doing anything with the list of net names. You either need to print it somehow, or you should use foreach(mapcar ...). For example:
      println(cv~>nets~>name)
    (use tilde-arrow rather than straight arrow, as otherwise the ->name won't work for each net).
    Or:
    foreach(mapcar cv allSchematics
      cv~>nets~>name
    which will give you a list of lists of all the net names for each cellView.
    You could also do:
    allSchematics~>nets~>name
    to achieve the same thing.
    If you're going to write SKILL code, it might be worth following one of the (free) training classes on SKILL Programming on http://support.cadence.com (use Learning→Online Courses to see what's there)
  • J P Cardoso
    I think something is not right.
    When I enter the commands below ...
    deOpenCellView("pedro" "tb" "schematic" "schematic" hiGetSessionWindow(hiGetCurrentWindow()) "r" )
    I get ....
    ("gnd!" "vprog" "vref" "out" "in")
    which is correct.
    However, when I try the recursive algorithm the output of the top level doesn't look right.
    db:0x3e4ca01a
    (("O")
    ("MINUS" "PLUS")
    ("PLUS" "MINUS")
    ("IN" "IP" "O" "R" "S")
    ("n" "p")
    ("gnd!")
    here vprog and vref are missing and the function is grabbing names of pins too, not only nets.
    Kind regards,
    Pedro
    Two things:
    1. The code as I provided uses a viewList of "schematic symbol". That means that if there's not a schematic view, it finds the symbol view. The CCFgetAllSchematics doesn't really take that into account (the function was badly named - this wasn't supposed to be the final solution - just something to get you started) - after all, I threw it together in a few minutes.
    2. Secondly, it doesn't include the top cellView.
    You can workaround this by doing:
    allSchematics=cons(topCV CCFgetAllSchematics(topCV ?viewList "schematic cmos.sch"))
    Note I gave two alternatives for the schematic view name - if you don't do that you get a bunch of warnings if you only give "schematic". You could just do this:
    allSchematics=cons(topCV CCFgetAllSchematics(topCV ?viewList "schematic schematic"))
    (normally specifying the view name twice is a bit pointless, but it's just a way of suppressing the warning you'd get otherwise).
  • J P Cardoso
    Thanks a lot Andrew. I really appreciate your help.
    Kind regards,
    Pedro
