  3. Edit Instance Property Window
  • Replies 8
  • Subscribers 150
  • Views 12390
amaru
amaru over 3 years ago
Hello there,
I have created a pcell with many parameters. When I query it to edit parameters, "Edit Instance Property Window" opens. It opens with a scroll bar. What I need is to increase the size of this window, but I am observing that the size of the window is fixed. I cannot change the size of this window. I tried to search the forum but couldn't find anything that can solve my problem. Other than this the window has 4 options - OK, Cancel, Apply and Help. I want to add default option as well to this window. I want to do it in skill.
If any more information is needed please let me know. Thanks
Virtuoso version - ICADVM20.1-64b.500.23
Amar
  • mbracht
    mbracht over 3 years ago
    Hi Amar,
    the resizing is controlled through an SKILL env variable:
    envSetVal("layout" "propertyEditorAutoResize" 'boolean nil)
    regards
    Max
  • RobMan
    RobMan over 3 years ago in reply to mbracht
    Just to add; this needs to be set on startup.
  • amaru
    amaru over 3 years ago in reply to RobMan
    Thanks Rob and Max. It worked for me.
    How can I add default option also in this menu? To set the pcell to default settings. Or any other workaround for it.
    Amar
  • RobMan
    RobMan over 3 years ago in reply to amaru
    Do you mean an option to reset the instance parameters to default values?
  • mbracht
    mbracht over 3 years ago in reply to amaru
    I don't think there is a way to customize this GUI - as far as I remember it is one of these old Motif GUIs hardcoded in C/C++. And the property editor doesn't have this feature either. So you'd have to rewrite the entire GUI in SKILL which I don't think is worth the stretch.
    Alternatively you could write a SKILL function that restores a Pcell's default values, then associate this function with a bindkey so as it is applied to the currently selected instance.
    Max
    Andrew Beckett over 3 years ago in reply to mbracht
    Max,
    It's not a Motif UI - that was replaced some time ago - but it is a native Qt form rather than one implemented in SKILL, so does not have the ability to be customised.
  • amaru
    amaru over 3 years ago in reply to Andrew Beckett
    Thanks Andrew, Max and Rob for your inputs. I will assign a bindkey to set the pcell for default value of parameters.
    Amar
  • p94todorov
    p94todorov over 3 years ago in reply to amaru
    Hi Amar,
    in addition to what has already been said, I can say that you can also include a button on top of your CDF parameters and reset all other parameters through the callback of that button. I think that if you do something as simple as that:
    ?callback "foreach(param cdfgData->parameters param->value = param->defValue)"
    you can achieve what you are looking for without having to re-do the Qt GUI interface.
    Petar
