  3. Getting terminal data and printing it in CIW
  • Views 10165
Tejaskill
Tejaskill over 3 years ago
Hi all,
I am looking for a code which can read terminal data and print it in CIW.
Example: If I call a child process through sh("./testrun.sh")
It will print some data in terminal but I need that data should be printed in CIW.
Is there any way to achieve this.
Teja.
  • ebecheto
    ebecheto over 3 years ago
    Here is a perfectible example to do so :
    ;; copyleft ebecheto
    defun( shout (command @optional (rmNL nil) (verb t) )
    (let (ipcId ret) ;// not to use with complex shell command , no time stamp specified
    ipcId=ipcBeginProcess(command)
    ipcWaitForProcess(ipcId)
    ret=ipcReadProcess(ipcId 30) ;=>"now you see it..."
    when(verb printf("SHELL>%s" ret))
    when(rmNL rexCompile("\n") ret=rexReplace( ret "" 1));<== bad idea if multiline answer...
    ret
    printf("shout(\"hostname\")\n")
    printf("ret=shout(\"ls *.log\")\n")
    printf("ret=shout(\"env\")\n")
    printf("ret=shout(\"echo $SHELL\")\n")
    printf("ret=shout(\"spectre -help bsim3v3\")\n")
    printf("ret=shout(\"cds_root virtuoso\")\n")
    ;printf("ret=shout(\"echo `date +'_%Hh%M_%F'`\")\n")
    printf("ret=shout(\"echo `date +'%%F_%%Hh%%M_'`\")\n")
    ;printf("ret=shout(\"echo `date +F`TATA\")\n")
  • mschw
    mschw over 3 years ago in reply to ebecheto
    I suppose that you can adapt the solution from this article very easily that it satisfies your needs.
    Matthias
  • Tejaskill
    Tejaskill over 3 years ago in reply to ebecheto
    Thanks for the reply but ipcReadProcess is only giving me 1 line output.
    I tried increasing the time limit but it still gives me less no of lines output
    My testrun.sh file may give 1000 lines output
    So I need a function which can print all that lines
    Teja.
  • AurelBuche
    AurelBuche over 3 years ago in reply to Tejaskill
    A simple solution consists in piping your shell command to a file, then you just have to read and delete the file in SKILL
    Otherwise using ipcBeginProcess, the following SKILL++ snippet should do the job nicely:
    (inScheme
    (defun shell_output (command)
      "Run COMMAND then return stdout, stderr and exit status it generated"
      (let ((stdout (outstring))
            (stderr (outstring))
            exit_status)
        (unwindProtect
          (progn
            ;; Run shell command and wait for it to finish
            (ipcWait
              (ipcBeginProcess command ""
                ;; Save stdout, stderr and exit status
                (lambda (_pid data) (fprintf stdout "%s" data))
                (lambda (_pid data) (fprintf stderr "%s" data))
                (lambda (_pid n   ) (setq exit_status n))
            ;; Return stdout, stderr and exit status
            (list (getOutstring stdout) (getOutstring stderr) exit_status)
          ;; Properly close outstrings whatever happened before
          (progn (close stdout) (close stderr))
    );inScheme
    Note that if you want stdout and stderr in one string as they would have been printed to the terminal, you can remove stderr definition in the let and replace stderr by stdout in the second lambda
    If you just want to print the output to the CIW and not get it in a string, you can also write a much simpler code
    (defun shell_print (command)
      "Run COMMAND while printing its stdout and stderr to CIW. Always return t"
      (ipcWait
          ;; Print stdout and stderr to CIW
          (lambda (_pid data) (printf "%s" data))
    Cheers,
    Aurel
  • Tejaskill
    Tejaskill over 3 years ago in reply to AurelBuche
    This is the code I was looking for
    Thanks for your help
    Teja.
