  3. Summing analog waveform bus
  • Views 8926
MatanR
MatanR over 3 years ago
I'm trying to create function that accepts an analog waveform bus for example (4 current waveforms) called mywave<3:0>
point is to execute the same thing I can do with plus(mywave<3> mywave<2> mywave<1> mywave<0>) OR mywave<3>+mywave<2>+mywave<1>+mywave<0>
my function looks like this (but not working - what am I doing wrong):
procedure( mrAnalogBusSum( waveforms )
  (cond
  ;; Handle a single Waveform
  ((drIsWaveform waveforms)
    ;  Create Empty Wave
    sumWaveForm = drCreateEmptyWaveform()
    sumWaveForm = sumWaveForm + waveforms
    ;return waveform
    sumWaveForm
  ) ;drIsWaveform
  ;; Handle a family of waveforms
  ((famIsFamily waveforms)
    (famMap 'mrAnalogBusSum waveforms )
  ) ;famIsFamily
   ;; Default option - return error
   (t
    (error "mrAnalogBusSum - can't handle %L type of data\nExpecting a waveform OR waveform family\n" wave)
 ) ;cond
) ;procedure
Thank you,
Matan.
    Matan,
    This is the same as the question in this post: https://community.cadence.com/cadence_technology_forums/f/custom-ic-skill/56753/how-to-write-a-calculator-function-working-in-assembler-that-will-operate-on-all-bits-of-a-bus (unfortunately I've not had a chance to write the code as I said I hoped to in that post) - just been too busy the last couple of months.
