  3. Required skill help to create circle, triangle, square,...
  • Views 10611
Required skill help to create circle, triangle, square, pentagon, hexagon donut creation
jpraveen
jpraveen over 3 years ago
I am looking forward to draw a triangle, square, pentagon, hexagon with donut using path segment. Any help will be helpful.
    This is really not clear. By "path segment" do you mean "pathSeg" objects? Because if you do, it won't work because pathSegs are only supported on 45-degree multiples. If you don't mean that, what do you mean? A screenshot of manually drawn shapes would help.
  • jpraveen
    jpraveen over 3 years ago in reply to Andrew Beckett
    Thanks for reply. Please find the image for the shapes which i need help to develop skill code.
    Andrew Beckett over 3 years ago in reply to jpraveen
    Well, this is just usage of dbCreateDonut, dbCreatePathSeg and a bit of maths. I threw together the code below as an illustration. First of all, the CCFcreateDiagPathSeg is just using the suggested approach for creating diagonal pathSegs with octagonal ends as described in the documentation for dbPathSeg. The rest of the functions are each creating the other objects - and all have been written to return a list of the resulting objects. Of course, change the maths to suit your needs - this was just an illustration.
    This does seem a rather strange thing to want to do, but I'm sure you have your reasons!
    procedure(CCFcreateDiagPathSeg(cv layer width beginPt endPt)
      let((mfgGrid diagWidth halfDiag halfWidth)
        mfgGrid=techGetMfgGridResolution(techGetTechFile(cv))
        diagWidth=round(width*sqrt(2)/mfgGrid)*mfgGrid
        halfDiag=diagWidth/2.0
        halfWidth=width/2.0
        dbCreatePathSeg(cv layer beginPt endPt diagWidth "custom" "custom"
          list(halfDiag halfDiag list(halfWidth halfWidth halfDiag halfWidth halfWidth halfDiag)))
    procedure(CCFcreateRing(layer radius width @optional (origin 0:0) (cv geGetEditCellView()))
      ; assume that the radius is the radius of the centre line (there isn't really a centre
      ; line since it's a donut, but the centre of the ring path)
      list(dbCreateDonut(cv layer origin radius+width/2.0 radius-width/2.0))
    procedure(CCFcreateTriangle(layer bottomLength width @optional (origin 0:0) (cv geGetEditCellView()))
      let((halfBottom)
        destructuringBind((origX origY) origin
          halfBottom=bottomLength/2.0
          list(
            CCFcreateDiagPathSeg(cv layer width origin origX+halfBottom:origY+halfBottom)
            CCFcreateDiagPathSeg(cv layer width origX+halfBottom:origY+halfBottom origX+bottomLength:origY)
            dbCreatePathSeg(cv layer origin origX+bottomLength:origY width "truncate" "truncate")
    procedure(CCFcreateSquare(layer edge width @optional (origin 0:0) (cv geGetEditCellView()))
        ; mapcon is like mapcan (it concatenates), but behaves like map (gets the remaining list)
        ; allows us to see the first two points in the remaining list to create the side
        foreach(mapcon remSide list(origin origX:origY+edge origX+edge:origY+edge origX+edge:origY origin)
          when(cdr(remSide)
            list(dbCreatePathSeg(cv layer car(remSide) cadr(remSide) width "extend" "extend"))
    procedure(CCFcreatePentagon(layer bottomLength sideLength width
      let((halfBottom)
          list(
              origX:origY+sideLength origX+halfBottom:origY+sideLength+halfBottom)
              origX+halfBottom:origY+sideLength+halfBottom origX+bottomLength:origY+sideLength)
            dbCreatePathSeg(cv layer origin origX:origY+sideLength width "extend" "truncate")
              origX+bottomLength:origY origX+bottomLength:origY+sideLength
    procedure(CCFcreateHexagon(layer bottomLength sideLength topLength width
      let((topOffset)
        topOffset=(bottomLength-topLength)/2.0
          list(
              origX:origY+sideLength origX+topOffset:origY+sideLength+topOffset)
              origX+bottomLength-topOffset:origY+sideLength+topOffset origX+bottomLength:origY+sideLength)
  • jpraveen
    Thank you Andrew for sharing.
