  3. envSetVal: Can't set the value of variable - it has not...
  • Views 2656
envSetVal: Can't set the value of variable - it has not been registered.
Saikiran IND
Saikiran IND over 3 years ago
I want to get 'elapsed time statistics'. I am trying to set environment variables as needed but I am getting below error. Any idea what is the problem? The Version is IC6.1.8-64B.500.5.
envSetVal("maestro.results" "enableRunStatisticInfoDisplay" 'boolean t)
*WARNING* envSetVal: Can't set the value of variable 'enableRunStatisticInfoDisplay',
in tool[.partition] 'maestro.results' - it has not been registered.
nil
Saikiran
    Saikiran,
    That's too old a version. It was added in IC6.1.8-64b.500.14 (ISR14). See How to get resource usage and simulation run statistics displayed in the results tab in ADE Assembler or Explorer . You also need to be using LSCS rather than ICRP.
  • Saikiran IND
    Saikiran IND over 3 years ago in reply to Andrew Beckett
    Thanks Andrew,
    I updated to the new version and it is working.
    Saikiran
