  3. Warning when I try create a pin in layout but does not create...
  • Views 10189
Warning when I try create a pin in layout but does not create a pin
psill00
psill00 over 3 years ago
I am creating pin in layout for vdd1 and vdd2 in a script
I get a warning of:
WARNING* (DB-270000): dbCreatePinOnTerm: Terminal with name 'vdd1' already exists
The layout cellview has nets vdd1 and vdd2 but the terminals have only vdd2
viewing the two nets db varialble I see the
vdd1 = netDb1~>name
nil = netDb1~>term~>name
vdd2 = netDb2~>name
vdd2 = netDb2~>term~>name
when I try to create a pin it does not create the pin for the vdd1 ( I use dbCreatePin )
when I try to create a pin from the Cadence Pin form labels I get the same warning and no pin created
Can you help create the vdd1 pin
Paul
    Paul,
    What do you get if you enter these two commands - please post the output of each:
    cv~>terminals~>name
    dbFindTermByName(cv "vdd1")~>net~>name
  • psill00
    psill00 over 3 years ago in reply to Andrew Beckett
    cv~>terminals~>name ( I omitted the other terms )
    "vdd0" "vdd1" "vdd2" "vss"
    "vdd2"
    Paul
    Andrew Beckett over 3 years ago in reply to psill00
    Paul,
    As you can see, you have the vdd1 terminal on the vdd2 net (there's no requirement for a terminal name to match the net name - this allows a different external to internal name). If you don't want that and want to create there vdd1 terminal on the vdd1 net, you'll need to delete the old terminal first:
    dbDeleteObject(dbFindTermByName(cv "vdd1"))
    Then you should be able to use dbCreatePin as you expected.
  • psill00
    psill00 over 3 years ago in reply to psill00
    Thanks it worked
