  3. How to use the schematic signal name to retrieve the signal...
  • Views 9302
How to use the schematic signal name to retrieve the signal data from spectre simulations results using Python SRR
MFahmy
MFahmy over 3 years ago
I am trying to read some spectre simulation database using a python script based on SRRKIT, however using the signal name from the Schematic/maestro expression (starting with the "/") returns an empty signal
results_db = srrDataBase("./ac.ac")
data_set =results_db.getDataSet('ac-ac')
sig_list =data_set.getSignalNameList()
# Here for example the returned signal of the dc source would be V0:p
# However the schematic/expression signal name is /V0/PLUS
signal = data_set.evalSignal('/V0/PLUS')
# trying to evaluate "/V0/PLUS" return an empty signal, while evaluating V0:p return the right signal object
I have read in a different post that the getData() skill function internally evaluates (or in this case maps) the signal names starting with a "/" , how can I achieve the same using using Python SRR ?
or how get the correct name mapping between the maestro expressions and the simulation database
SRR KIT version: SRRKIT_20.10-d468
virtuoso : ICADVM20.1-64b.500.28
Spectre: sub-version  21.1.0.546.isr13
Fahmy
    Fahmy,
    Please contact customer support for this. All SRR Kit support should be done that way (as it a special add-on capability and not something that is shipped with Virtuoso or Spectre as standard).
  • MFahmy
    MFahmy over 3 years ago in reply to Andrew Beckett
    will do, thanks for the prompt reply
  • MFahmy
    actually I ended up trying to use python SRR as I thought I would be able to get around the schematic to simulator name mapping issues
    hoping python SRR will take care of the mapping, same way as the getData() function does,
    is there a straight forward way that maybe I am missing to get the schematic to simulator name mapping, including evaluating any functions in the mapped name as the mapping info seems to be part of the netlisting
    the mapping issue is described here
    described here: https://community.cadence.com/cadence_technology_forums/f/custom-ic-skill/56851/how-to-evaluate-the-termmapping-for-spectre-when-it-contains-a-function
    Fahmy
