  3. Ocean Script to read from the .log file
  • Views 8146
Saikiran IND
Saikiran IND over 3 years ago
I am running a simple DC simulation in Maestro . I want to get read the final simulation log file using ocean script and output DC simulation time as an output expression.
For example if the log file has this expression "DC simulation time: CPU = 1.94 ms", then the output of that expression should be 1.94m.
It would be of great help if anyone can help me with this script.
Saikiran
    Andrew Beckett over 3 years ago +1
    Perhaps you could use How to get resource usage and simulation run statistics displayed in the results tab in ADE Assembler or Explorer If not, How to parse Output Log File within ADE Assembler An…
  • Saikiran IND
    Saikiran IND over 3 years ago in reply to Andrew Beckett
    Thanks Andrew. The output log parsing works for my requirement.
    The "runstatistics" gives only the total elapsed time. I wanted only the "DC Simulation time" part of it.
    Regards
    Saikiran
