  3. hiInsertMenuItem: All menu item symbols must be unique....
  • Views 1464
hiInsertMenuItem: All menu item symbols must be unique. Item ('slider_menu_tm) not added.
KurtKimber1
KurtKimber1 over 3 years ago
A third-party tool is trying to place a pulldown menu on a Virtuoso schematic banner, but gets the following:
  WARNING: hiInsertMenuItem: All menu item symbols must be unique. Item ('slider_menu_tm) not added.
Could you help me troubleshoot this?
Thank you,
Kurt
  • AurelBuche
    AurelBuche over 3 years ago
    The warning message is quite explicit, there is already another menu item having the same name
    Either the tool you are trying to setup is loaded twice or you have another tool with overlapping names
    Do you have access to the source code of the third-party tool you are loading?
    If you don't it might be complicated to debug...
    You can still start by checking the existing menus to find which menu item is already named 'slider_menu_tm and see where it comes from
    Hope this helps,
    Aurélien
