  3. Attain layout vs schematic XL connectivity
  • Views 8696
mattab
mattab over 3 years ago
Is there any latest feature in virtuoso to get the XL connectivity between  schematic and layout. (LVS clean)
I am not looking for a device-to-device correspondence,but a feature which will do the job at once
Assume   layout vs schematic instance names are not matching  but pcells point to the tech libs
thanks in advance!!
  • KSSB
    KSSB over 3 years ago
    Try the Update Binding option under connectivity menu. It should work on LVS clean layout
  • RobMan
    RobMan over 3 years ago in reply to KSSB
    Certainly 'Update Binding' is the way to start, but it's not necessarily the case that LVS clean layout will comply. An XL compliant layout would be a more correct terminology. Take a simple case; LVS will typically use labels as pin/terminal correspondence points. XL will require a pin shape.
