  3. Unable to change the environment value of quickalign
  • Subscribers 150
  • Views 8852
Tejaskill
Tejaskill over 3 years ago
Hi all,
I am using ICADVM18.1
I know about changing the environment variables using envSetVal command, but I am unable to change the environment variable of quick align using.
envSetVal("layout" "quickAlignSpacingType" 'cyclic "user")
After executing the above line, I am unable to change the quick align spacing type to user in the current window.
I also tried hiGetCurrentWindow()->quickAlignSpacingType->"user", but it was also not helping.
Can anyone help me what I am missing.
Teja.
    Teja,
    I just tried this in IC6.1.8-64b.500.32 (I didn't have ICADVM18.1 to hand) and changing the environment variable does have an effect on the quick align right mouse button menu and options form. Can you clarify:
    1. What exactly doesn't work when you change the env var?
    2. Which sub-version you're using (calling getVersion(t) will report that)?
    Then I can do some checks in the precise version you're using. I found some change requests for issues with this which were fixed in IC6.1.4 and then a specific issue fixed in an IC6.1.7 hotfix, but 18.1/6.1.8 is well beyond that.
  • Tejaskill
    Tejaskill over 3 years ago in reply to Andrew Beckett
    Thanks for the reply,
    1. I need to Toggle the offset in Align Form >>> From User spacing to No spacing, as shown in figure.
    2. I am using sub-version ICADVM18.1-64b.500.7
    I have also checked in IC6.1.8-64b.500.7, Still I am not able to achieve the result.
    My code I am using is,
    tk1=hiCreateButton(?name 'TK
                                    ?callback "qau()"
                                    ?buttonText "User Spacing"
    tk2=hiCreateButton(?name 'TK1
                                    ?callback "qau1()"
                                    ?buttonText "No Spacing"
    tkform=hiCreateAppForm(?name 'Quick Align
                                              ?fields list(tk1 tk2)
                                              ?formTitle "Align"
    procedure(qau() envSetVal("layout" "quickAlignSpacingType" 'cyclic "user"))
    procedure(qau1() envSetVal("layout" "quickAlignSpacingType" 'cyclic "none"))
    hiDisplayForm(tkform)
    When I click user button in my form, I should have user spacing as offset in align form and same for no spacing.
    Could you please help me.
    Teja.
  • RobMan
    RobMan over 3 years ago in reply to Tejaskill
    I checked in ICADVM18.1-64b.500.7 and it doesn't appear to work. Look like you might need to move to a more recent version.
  • RobMan
    FYI: It's fixed in ISR13
