  3. Strongly connected pins inside pcells
  • Subscribers 152
  • Views 9102
RVERP
RVERP over 3 years ago
I have a pcell where I create pins using rodCreateRect. I have multiple pins on top of each other and I want those to be strongly connected. They are all created with rodCreateRect and they are given the same netName and termName
Like this:
rodCreateRect(
?name "PIN1"
?layer "LAYER"
?width 1
?length 1
?netName "A"
?termName "A"
?pin t
rodCreateRect(
?name "PIN2"
?layer "LAYER"
?width 1
?length 1
?netName "A"
?termName "A"
?pin t
I order to do that they all must be pinFigs from the same pin, but how do I do that in this situation?
    You can do it this way:
    PIN1=rodCreateRect(
      ?name "PIN1"
      ?cvId cv
      ?layer "Metal2"
      ?width 1
      ?length 1
      ?netName "A"
      ?termName "A"
      ?pin t
    PIN2=rodCreateRect(
      ?name "PIN2"
      ?cvId cv
      ?layer "Metal3"
      ?width 1
      ?length 1
      ;?netName "A"
      ;?termName "A"
      ;?pin t
    dbAddFigToPin(PIN1~>dbId~>pin PIN2~>dbId)
    I then checked on the support site and found exactly the same approach was described in this app note: Implementing Open Access Pin Connectivity Model in SKILL Pcells
  • RVERP
    RVERP over 3 years ago in reply to Andrew Beckett
    Seems to work, thanks Andrew.
  • FabianUSA
    FabianUSA over 3 years ago in reply to Andrew Beckett
    Hello
    In the case the multiple pins are created with the following code
    PIN1=rodCreateRect(
      ?name "PIN1"
      ?cvId cv
      ?layer "Metal2"
      ?width 1
      ?length 1
      ?netName "A"
      ?termName "A"
      ?pin t
    ?elementsX 3
    ?pinLabel t )
    How is it possible to make them strongly connected please?
    Andrew Beckett over 3 years ago in reply to FabianUSA
    Hi Fabian,
    You can't - you have to use the approach that I described earlier in the thread.
