  3. Consult a skill for find cell placement
  • Views 9794
Jewell
Jewell over 3 years ago
Please consult everyone,
I want to achieve the following functions:
1; Open an any Top layout cell, assuming that there have been many calls to common cell A in this Top layout. Entering a common cell A, pressing a bindkey can list all common cell A called in the entire Top layout
2;After finding all common cells A, zoom in on one part of a common cell and click Next through the window to display the same points for browsing all common cells at the same magnification, in order to check if your edit meets all points and avoid errors such as LVS and DRC
Thank all .
  • mschw
    mschw over 3 years ago
    Hi Jewell,
    have you tried using the Find/Replace form, accessible from the menu bar Tools>Find/Replace in the layout editor?
    Matthias
  • Jewell
    Jewell over 3 years ago in reply to mschw
    Hi,Matthias
    Use search and replace,must switch to the specified hierarchical to search,very trouble, and not all cells can zoom to a single point and sync. The function I want is to directly find all the same cells in the opened layout at any level, and all cells can be zoomed and  synchronized at one point for observation
    Jewell
  • Jewell
    Isn't anyone willing to lend a helping hand?
  • Jewell
    The difference between the feature I want and the find feature that comes with cadence is: 1. There is no need to actively fill in the name of the cell you want to search for. You only need to enter the specified cell to know the name of the cell you want to search for. 2. After entering the cell, you can search for all levels of the open layout, instead of the find function that comes with cadence, which can only search up or down
  • RobMan
    RobMan over 3 years ago
    You should be able to use the Navigator Assistant: Filter the instances to list only the cell of interest. Then refer to these envars to control the auto zoom...
    envSetVal("layout" "autoZoomMode" 'cyclic "Zoom")
    envSetVal("layout" "autoZoomPan" 'boolean t)
    envSetVal("layout" "autoZoomScale" 'int 90)
    Step through instance selection in the Assistant.
  • ebecheto
    ebecheto over 3 years ago
    Hi Jewel,
    Here is a pseudo code exemple on how to zoom in.
    Although, i do not remember how to make a blocking user input pause.
    You can imagine to highlight a net with lntAddTrace / lntRemoveAllTraces()  before /after zooming.
    This code will not work, but it will give you a starting point maybe.
    ;; copyleft ebecheto
    defun(xy2bBox  (xy @optional (d 0.5) ) let(( x y) x=car(xy) y=cadr(xy) list(list(x-d y-d) list(x+d y+d)) ))
    ;; xy point to a square bBox at this point
    ;;  |  xy |
    ;; return bounding Box around the point
    ;;inst=css()
    foreach(mapcar inst  setof(inst win~>cellView~>instances inst~>name==sprintf(nil "matgen[%d].c_col_pixel_cfg" C)))
    hiZoomIn(win=getCurrentWindow() xy2bBox(inst~>bBox 35))
    ;; Make a wait her somehow or save the image
    filename=sprintf(nil "%s%03d_%s.png" pattern i pixName);=> "Bzoom003.png"
    hiWindowSaveImage(?target win ?path filename ?centralWidget t)
