  3. How to create a through separator line in a layout form...
  • Views 9107
How to create a through separator line in a layout form?
Martinsh
Martinsh over 3 years ago
In following example, a horizontal separator is inserted in the form. But the separator line is not a through horizontal line and it can't cover the label part of the fields on the form. How to create a through separator on the form?
FORM2=hiCreateLayoutForm(
'NPN_
"NPN "
hiCreateFormLayout(
'main_layout
?spacing 10
?label_align 'center
?items (list
hiCreateStringField(
?name 'SF1
?prompt "SF1aaaaaaa "
?editable t)
hiCreateSeparatorField(
?name 'sep1)
?name 'SF2
?prompt "SF2bbbbbbb"
?editable t)
?name 'SF3
?prompt "SF3ccccccc"
?editable t)
));main_layout
);display_form
hiDisplayForm(FORM2)
Best regards,
Martin
  • AurelBuche
    AurelBuche over 3 years ago in reply to Andrew Beckett +1
    Hi Andrew, For once I might have a simpler solution than yours Wrapping the separator in an horizontal box layout should work: FORM2 = hiCreateLayoutForm( ' NPN_ "NPN " hiCreateFormLayout (…
    Martin,
    Form layouts don't have much control - they are intended to be simple and convenient, but don't give the full controls that (say) a Grid layout would. The downside of grid layouts however is that you normally end up having to create the prompts as labels so that the prompts align (otherwise the overall containers align rather than the entry boxes). If I do this (and use 'col_span to span columns), this works:
      'NPN_
      "NPN "
      hiCreateGridLayout(
        'main_layout
        ?spacing 10
        ?items
          list(
            list(
              hiCreateLabel(
                ?name 'SF1lab
                ?labelText "SF1aaaaaaa"
              'row 0 'col 0
            list(
                ?name 'SF1
                ?editable t
              'row 0 'col 1
            list(
                ?name 'sep1
              'row 1 'col 0 'col_span 2
            list(
              hiCreateLabel(
                ?name 'SF2lab
                ?labelText "SF2bbbbbbb"
              'row 2 'col 0
            list(
                ?name 'SF2
                ?editable t
              'row 2 'col 1
            list(
              hiCreateLabel(
                ?name 'SF3lab
                ?labelText "SF3ccccccc"
              'row 3 'col 0
            list(
                ?name 'SF3
                ?editable t
              'row 3 'col 1
            list('col_stretch 0 0)
            list('col_stretch 1 1)
  • AurelBuche
    'NPN_
    "NPN "
    hiCreateFormLayout(
    'main_layout
    ?spacing 10
    ?items (list
    ?name 'SF1
    ?editable t)
    hiCreateHorizontalBoxLayout( 'sep1_wrap_layout
      ?items list( hiCreateSeparatorField( ?name 'sep1)))
    ?name 'SF2
    ?editable t)
    ?name 'SF3
    ?editable t)
    ));main_layout
    );display_form
    Cheers,
    Aurélien
    Andrew Beckett over 3 years ago in reply to AurelBuche
    Excellent idea Aurélien. That’s a much simpler solution!
  • Martinsh
    Martinsh over 3 years ago in reply to Andrew Beckett
    Thanks Andrew and Aurelien. Both the ways are good for me.
    Martin
