  3. Disable a menu item in schematic window but enable it in...
  • Subscribers 152
  • Views 8902
Disable a menu item in schematic window but enable it in layout window
Martinsh
Martinsh over 3 years ago
A pull down menu is created and loaded in schematic and layout windows. One of the menu item is just for layout. So I'd like it being enable in layout window and disabled in schematic window. How to do?
Best regards,
Martin
    Martin,
    Unfortunately the underlying mechanism which allows a trigger on the menu being posted (so it can dynamically enable/disable menu items) isn't documented - I have change request CCR 1388189 asking for this. You might want to contact customer support asking for a duplicate to be filed on your behalf (so far nobody else has asked for this other than me!)
    In the absence of that, I think you'll need to create a separate pulldown menu for each application with the same contents, with a separate menu item for the entry you want to be differently enabled/disabled.
  • Martinsh
    Martinsh over 3 years ago in reply to Andrew Beckett
    Thanks Andrew. I will follow your advice and separate the pulldown menu.
    Martin
  • revida marcos
    revida marcos over 3 years ago
    You may use conditional expressions based on the currently active window to deactivate a menu item in the schematic window but enable it in the layout window. The specific menu item can be enabled or disabled in your code based on whether the active window is the schematic window or the layout window.
    Here is a simple pseudo-code illustration:
    if active_window == "schematic":
    menu_item.enable = False
    elif active_window == "layout":
    menu_item.enable = True
    Users won't be able to interact with the menu item since it will be disabled in the schematic window (menu_item.enable = False). The menu item will be made usable by being enabled in the layout window (menu_item.enable = True).
    you identify the presently active window in your particular programming environment or framework, be sure you replace active_window with the proper code or function call.
    Hope this is useful!
  • Martinsh
    Martinsh over 3 years ago in reply to revida marcos
    Dear marcos,
    Yes, we can enable/disable menu items by the conditional code. But it needs a trigger event to run the conditional code. How to register the trigger event?
    Martin
    Andrew Beckett over 3 years ago in reply to Martinsh
    Martin,
    Unfortunately the reply was rather generic; the trigger you need exists, but is not public...
