  3. Run a shell command through ipc in a specified director...
  • Views 11051
Run a shell command through ipc in a specified directory
Martinsh
Martinsh over 3 years ago
I'd like to run CDLout with a skill script. An si.env setup file is created in directory ~/simulation. So I'd like to run the command "si -cdslib cds.lib -batch -command netlist > si.log" in ~/simulation directory.
My understand, ipcBeginProcess("si -cdslib cds.lib -batch -command netlist > si.log" ) will run the si command in current directory, not ~/simulation, and can't access the si.env file in ~/simulation directory.
Then how to run the "si -cdslib cds.lib -batch -command netlist > si.log" command through ipc to access the si.env file in ~/simulation directory?
Martin
  • AurelBuche
    AurelBuche over 3 years ago
    Hi Martin,
    As long as you are running shell commands, why don't you just do a cd command before the si one ?
    ipcBeginProcess("cd ~/simulation ; si -cdslib cds.lib -batch -command netlist > si.log" )
    Cheers,
    Aurel
    Andrew Beckett over 3 years ago in reply to AurelBuche
    Or simpler still, just give the run directory to the si command (since it supports that; see "si -help"):
    ipcBeginProcess("si ~/simulation -batch -command netlist > si.log")
    You don't need to pass the -cdslib necessarily (since the the default would be to pick up cds.lib), but if you did it the way that Aurélien suggested, you'd need to pass -cdslib and give the full path to the cds.lib in the working directory that Virtuoso is running in.
  • Martinsh
    Martinsh over 3 years ago in reply to Andrew Beckett
    Hi Andrew, Aurel,
    Thanks. Both of the ways work well. But there is another problem. If I run
    in a terminal, the netlist process is fast and need time of ~1s to complete. But if I run it through skill ipc command, as
    cid1 = ipcBeginProcess("si ~/simulation -batch -command netlist > si.log")
    ipcWait(cid1)
    it will take much more time, ~10s. Before the netlist process complete, it reports two times of
    Waiting for ipc:518 to terminate
    What's the problem? How to solve it?
    Martin
    Andrew Beckett over 3 years ago in reply to Martinsh
    Martin,
    No idea - I can't think of any particularly good reason why this should take any different amount of time. Is there any clue in the si.log file?
    Perhaps you could contact customer support?
  • Martinsh
    Restart virtuoso solves the problem.
    Martin
