  3. Run ipc command in multi-thread
  • Views 8132
Martinsh
Martinsh over 3 years ago
How to run ipc command in multi-thread?
For example, 100 tasks will run on 5 threads.  At begining, the first 5 tasks are arranged on 5 threads. When one of the 5 tasks is completed, next task start automaticlly. There are always 5 tasks runing until no taskes left.
Martin
  • AurelBuche
    AurelBuche over 3 years ago
    Hi Martin,
    Not sure you could really call that multi-threading but here is a SKILL++ function that should do the job you're asking for :
    (inScheme
      (defun ipc_run_parallel (commands threads "lx")
        "Run COMMANDS in several parallel THREADS"
        (defun run_next_command nil
          (let ((command (pop commands)))
            (when command
              (ipcBeginProcess command ""
                (lambda (_pid _data)   nil)
                ;; Start next thread when the current one is finished
                (lambda (_pid _status) (run_next_command))
        ;; Start several threads in parallel
        (for i 1 threads (run_next_command))
    You can use it like :
    (ipc_run_parallel '("sleep 1" "sleep 2" "sleep 3" "sleep 4") 4)
    Cheers,
    Aurélien
