  3. Get ipcReadProcess() return message in real time and update...
  • Views 8254
Get ipcReadProcess() return message in real time and update form field
Martinsh
Martinsh over 3 years ago
If we run an ipc process use with cid1 = ipcBeginProcess() function and get feedback message with ipcReadProcess(cid1) function, can we get the feedback and update a milti-line string form field in real time?
Martin
  • AurelBuche
    AurelBuche over 3 years ago
    Hi Martin,
    You should check the arguments of ipcBeginProcess, it takes a function as third and fourth argument exactly for these kind of purpose
    ipcBeginProcess( "your_shell_command" ""
      (lambda (pid data) your_form_name->field_name->value = strcat( your_form_name->field_name->value data))
  • Martinsh
    Martinsh over 3 years ago in reply to AurelBuche
    Hi Aurel,
    Thanks, it works. Now the feedback message can be updated in the form field in real time.
    Another question, I want to realize a function like this,
    1. Start a child process with ipcBeginProcess() function.
    2. Receive data from the child process and update it in a form field in realtime.
    3. When the child process is competed, update the final result in another form field.
    If we use an ipcWait() function follwing the ipcBegainProcess() command, even we use the dataHandler function to receive data from the child process, the data received can't be updated in the form field in real time, because the main skill program will be blocked by the ipcWait() function.
    If we don't put an ipcWait() function following the ipcBeginProcess() command,  the main skill programm will run to complele before the child process and can't get the proper final result of the child process.
    How to solve this problem?
    Martin
  • AurelBuche
    AurelBuche over 3 years ago in reply to Martinsh
    Hi Martin,
    Most of the questions you ask are already answered in the documentation of ipcBeginProcess
    Read it carefully, you'll find what you need
    From my point of view it seems you ask many questions without even looking at the documentation nor trying by yourself before...
    Cheers,
    Aurélien
