  3. how can get layout cellView ID from xl open schematic win...
  • Views 9168
how can get layout cellView ID from xl open schematic win or cv ID in virtuoso
alaylayla
alaylayla over 3 years ago
  • RobMan
    RobMan over 3 years ago
    There is no direct link from the binding schematic to the layout. Only the reverse is true: The layout physConfig refers to the connectivity reference (schematic).
  • alaylayla
    alaylayla over 3 years ago in reply to RobMan
    how can i use the schematic cv or win iD toget link physConfig file,and than get bind layout
  • alaylayla
    alaylayla over 3 years ago in reply to alaylayla
    i read cph prefix api,them need parameter “g_physConfigID”,how can i get these;
    Andrew Beckett over 3 years ago in reply to alaylayla
    This approach is fundamentally flawed. As was mentioned earlier, there's no direct link from the schematic to the layout. The same schematic can be used with either the same or different physConfigs to generate different layouts. So whilst you can get the physConfig from the configured schematic by using:
    hdbId=deGetConfigId(hiGetCurrentWindow())
    cphId=cphFindOpenConfig(hdbGetLibName(hdbId) hdbGetCellName(hdbId) hdbGetViewName(hdbId))
    this is not going to help you. The physical config doesn't store the top physical cellView - that's only displayed in the CPH UI when you launch it from the layout (and it knows the layout in that case). Similarly, if the schematic is used with multiple physConfigs, you'd see the banner changing in the schematic as you interact with the different layouts.
    So to summarise, what you're asking for doesn't make sense because there's not a unique relationship from schematic to layout. There is a unique relationship the other way around (from layout to the connectivity source), but not from schematic to layout.
