  3. What is the difference between instance master and header...
  • Subscribers 152
  • Views 9541
What is the difference between instance master and header?
alaylayla
alaylayla over 3 years ago
What is the difference between instance master and header? Which one to use when traversing the library hierarchy or topcell
  • AurelBuche
    AurelBuche over 3 years ago
    If you are traversing the hierarchy you will most likely use the masters
    Here is a little recap :
    - master : it is the reference cellview you instantiate in your current design
    - instance : it contains all the properties to be used with your master (at least origin, orientation and pCells parameters when the master is a pCell)
    - header : it is a reference for a group of instances having the same parameters (but not the same origin, orientation)
    Hope this helps,
    Cheers
    Aurélien
  • alaylayla
    alaylayla over 3 years ago in reply to AurelBuche
    thanks
