  3. The background gives tansCdlOutForm parameters to export...
  • Replies 8
  • Views 11138
The background gives tansCdlOutForm parameters to export Cdl files. The first two exported cdl files are incomplete
alaylayla
alaylayla over 3 years ago
Why is this script executed in the background for the first two times after virtuoso is first started without opening XStreamOutui in the graphical interface, and the exported cdl file is not complete; the exported cdl file is complete after the third time. The first two times, the log in the ciw is prompted that the job is completed, and there are no prompts for error and warning; I don't know how the si.log file looks, but there seems to be a warning log in it. Why is this and what is it related to? How can I modify this code to avoid the results of the first two executions after virtuoso is first started are wrong.
    I'm not going to spend time debugging your code from a screenshot - I can't execute that and can't perform experiments to find out what is wrong. I don't see what the "XStreamOutUI" has to do with it - this is a CDL export code. Also, I don't understand why you have a timer to display the form and then another to cancel it - these will execute after the rest of the code has run (which looks wrong).
    If you want some help, please post the actual code (as text) so that anyone helping can try it out without having to re-type in the code.
  • alaylayla
    alaylayla over 3 years ago in reply to Andrew Beckett
    procedure(ExportCdlForm()
    getCdlName()
    RunDir = hiCreateFileSelectorField(
    ?name 'RunDir
    ?mode 'directoryOnly
    ?prompt "Run Directory"
    ?defValue "./verify/cdl"
    LibName = hiCreateStringField(
    ?name 'LibName
    ?prompt "Library Name"
    ?defValue LibName
    ?callback "dmbUpdateBrowser()"
    CellName = hiCreateStringField(
    ?name 'CellName
    ?prompt "Cell Name"
    ?defValue CellName
    ?callback "CellNameCB()"
    ViewName = hiCreateStringField(
    ?name 'ViewName
    ?prompt "View Name"
    ?defValue ViewName
    ?callback "ViewNameCB"
    CdlName = hiCreateStringField(
    ?name 'CdlName
    ?prompt "Cdl Name"
    ?defValue CdlName
    IncludeFile = hiCreateFileSelectorField(
    ?mode 'existingFile
    ?name 'IncludeFile
    ?prompt "Include File"
    ?defValue ""
    Browser = hiCreateButtonBoxField(
    ?name 'Browser
    ?prompt ""
    ?choices '("Browse")
    ?callback list("Browser()")
    ExportCdlForm = hiCreateAppForm(
    ?name 'ExportCdlForm
    ?formTitle "Export Cdl"
    ?callback "ExportCdlMain()"
    ?buttonLayout 'OKCancelApply
    ?minSize 560:150
    ?fields list(list(RunDir 0:0 505:30 100)
    list(LibName 0:30 480:30 100)
    list(CellName 0:60 480:30 100)
    list(ViewName 0:90 480:30 100)
    list(CdlName 0:120 480:30 100)
    list(Browser 476:32 20:26 )
    list(IncludeFile 0:150 505:30 100))
    hiDisplayForm('ExportCdlForm)
    );proc
    procedure(Browser()
    dmbSyncWithForm(ExportCdlForm 'browse 'LibName 'CellName 'ViewName)
    procedure(CellNameCB()
    let(()
    dmbUpdateBrowser()
    ExportCdlForm~>CdlName~>value=strcat(ExportCdlForm~>CellName~>value ".cdl")
    );let
    );proc
    procedure(ViewNameCB()
    let(()
    dmbUpdateBrowser()
    when((ExportCdlForm~>LibName~>value!="") && (ExportCdlForm~>CellName~>value!="") && (ExportCdlForm~>ViewName~>value!="")
    unless(dbOpenCellViewByType(ExportCdlForm~>LibName~>value ExportCdlForm~>CellName~>value ExportCdlForm~>ViewName~>value)~>cellViewType=="schematic"
    hiDisplayAppDBox(
    ?name 'ViewNameError
    ?dboxBanner "Error"
    ?dboxText "Select CellView is not Schematic!"
    ?buttonLayout 'YesNo
    ?callback "ExportCdlForm~>ViewName~>value=\" \""
    ?dialogType hicErrorDialog
    ?dialogStyle 'modal
    );unless
    );let
    );proc
    procedure(getCdlName()
    let((cv)
    if(cv=geGetEditCellView() then
    if(cv~>cellViewType=="schematic" then
    LibName = cv~>libName
    CellName = cv~>cellName
    ViewName = cv~>viewName
    CdlName = strcat(CellName ".cdl")
    );if
    else
    unless((boundp('LibName) && boundp('CellName) && boundp('ViewName))
    LibName = ""
    CellName = ""
    ViewName = "schematic"
    CdlName = ""
    );unless
    );if
    );let
    );proc
    procedure(ExportCdlMain()
    prog(()
    unless(isDir(ExportCdlForm~>RunDir~>value) ipcBeginProcess(strcat("mkdir -p " ExportCdlForm~>RunDir~>value)));unless
    if(((ExportCdlForm~>RunDir~>value !="") && (ExportCdlForm~>LibName~>value !="") && (ExportCdlForm~>CellName~>value !="") && (ExportCdlForm~>ViewName~>value !="") && (ExportCdlForm~>CdlName~>value !="")) then
    hiRegTimer("transCdlOutDisplay()" 0)
    hiRegTimer("hiFormCancel(transCdlOutForm)" 0)
    transCdlOutForm~>cdlORunDir~>value = ExportCdlForm~>RunDir~>value
    transCdlOutForm~>cdlOLibName~>value = ExportCdlForm~>LibName~>value
    transCdlOutForm~>cdlOTopCell~>value = ExportCdlForm~>CellName~>value
    transCdlOutForm~>cdlOViewName~>value = ExportCdlForm~>ViewName~>value
    transCdlOutForm~>cdlONetlistFile~>value = ExportCdlForm~>CdlName~>value
    transCdlOutForm~>cdlONetlistingMode~>value = "Analog"
    transCdlOutForm~>cdlOPinmap~>value = t
    transCdlOutForm~>cdlODisplayPinInfo~>value = nil
    transCdlOutForm~>cdlOPreserveBangInNetlist~>value = t
    transCdlOutForm~>cdlOIncFile~>value = ""
    unless(IncludeFile~>value == ""
    if(isFile(IncludeFile~>value) then
    transCdlOutForm~>cdlOIncFile~>value = IncludeFile~>value
    else
    hiDisplayAppDBox(
    ?name 'IncludeFileError
    ?dboxBanner "Error"
    ?dboxText "Error Include File!"
    ?dialogStyle 'modal
    return(nil)
    );if
    );unless
    hiFormDone(transCdlOutForm)
    else
    hiDisplayAppDBox(
    ?name 'NoCellSelect
    ?dboxBanner "Error"
    ?dboxText "Error Cell Select!"
    ?dialogStyle 'modal
    );if
    );prog
    );procedure
  • alaylayla
    Thank you senior, the problem has not been solved, I can't find the reason; the test found whether opening the cdlout form with a timer before execution affects the output
    Andrew Beckett over 3 years ago in reply to alaylayla
    Which IC sub-version are you using? I tried calling ExportCdlForm() in IC6.1.8-64b.500.32 and it worked fine the first time. It also worked fine if I commented out the hiRegTimer() lines - I don't know what they are there for.
  • alaylayla
    thanks i use IC6.1.8-64b.500.23,
  • alaylayla
    I may not explain clearly enough. After reopening virtuoso every time, I do not manually open the CDL OUT gui, and execute this script on the same cellview; the exported cdl file can be completed, but the content is incomplete; the second time for the same cellview After execution, gui automatically opens the cdl file. After the first execution, gui does not automatically open it. The exported cdl file, although ciw prompts that the job is completed, and the files related to the export path are generated, but the re-exported cdl file is still incomplete; after the third execution, gui automatically opens, and the cdl file is Yes, the complete one; it is strange that if you do not restart, every execution after the third time will be normal; if you execute it with another cellview, you can also export the complete cld file for the first time. In addition, if the code of opening and closing the cdl ui form is commented out with timing, the complete cdl file will not be imported no matter how many times it is executed. Note that after restarting, as long as you manually open the gui of cdl out and execute this script in the future, no matter whether the gui form that opens cdl out is executed in the script or not, these strange problems will not occur. What can cause this? This seems to be a problem with the initialization of key parameters; I am very worried about accidentally exporting incomplete netlist files
  • alaylayla
    alaylayla over 3 years ago in reply to alaylayla
    thanks i,My guess may be caused by the fast calculation of the CPU or the underlying code. Similar to shell scripts, in order to avoid Xsrteam out gds starting to run lvs before it is over, you need to add a sleep statement and wait.
  • alaylayla
    thanks.i have sloved
