  3. hi*Layout expanding string/button fields in the gui
  • Views 4378
psill00
psill00 over 3 years ago
Using hi*LayoutForm is there a way to expand the size of the string/button fields in the gui?
I have looked at the sample example CCSformLayout.il
I dont see a way expanding the size of the button/string fields and changing the placement of the form items as the gui changes in size.
One more question if the above is possible, when adding and is option in the add item that need to be added to change the size of the button/string?
When I use the function hiCreateAppForm I can change the size of a button/string fields with the variable ?attachmentList
Paul
  • AurelBuche
    AurelBuche over 3 years ago
    Hi Paul,
    This is just because the form you are looking at is using `hiCreateButtonBoxField' and not `hiCreateButton'
    Here is an example that should provide you with everything you need regarding form layouts:
    (hiDisplayForm
      (hiCreateLayoutForm 'custom_form "Custom Form"
        (hiCreateFormLayout 'main_layout ?items (list
            (hiCreateButtonBoxField
              ?name   'buttonField1
              ?prompt ""
              ?choices  '("Browse"     "Display"    )
              ?callback '("CCSbrowsed" "CCSdisplay" )
            (hiCreateHorizontalBoxLayout 'buttons_layout ?items (list
                '(spacer_item 20)
                (list
                  (hiCreateButton ?name 'button0 ?buttonText "Stretch 1" ?callback (lambda (@rest _args) nil))
                  'stretch 1)
                '(stretch_item 1)
                (list
                  (hiCreateButton ?name 'button1 ?buttonText "Stretch 2" ?callback (lambda (@rest _args) nil))
                  'stretch 2)
                (hiCreateButton ?name 'button2 ?buttonText "No Stretch" ?callback (lambda (@rest _args) nil))
                ));buttons_layout
            ));main_layout
    Note that stretch, stretch_item and spacer_item only works inside `hiCreateHorizontalBoxLayout' and `hiCreateVerticalBoxLayout'
    If you use `hiCreateFormLayout' your fields will not expand vertically although the field prompts will align nicely
    Hope this helps,
    Aurélien
  • psill00
    psill00 over 3 years ago in reply to AurelBuche
    Thanks for the info
    It has helped a lot on understanding the hi*Layout forms
    Is there a way to either have the fields larger or stretchable in the vertical or y direction?
    Paul
    Andrew Beckett over 3 years ago in reply to psill00
    Fields will "stretch" vertically too (provided that you are allowing it in the appropriate layout). However, for most fields it doesn't make sense for them to get larger vertical (unless the fonts are increased in size); there are exceptions such as multi-line text fields, list boxes and so on - these clearly make sense to grow vertically.
  • psill00
    psill00 over 3 years ago in reply to Andrew Beckett
    Its good to know it s possible ( a hint on how to do it would be nice )
    Reviewing the functions hi*Layout, it seems the functions to create the form would be below ( rough skeleton of rht format I will use )
    hiCreateLayoutForm('ExGridLayout "Grid"
          hiCreateVerticalBoxLayout('vbox
              ?items list(
                    hiCreateGridLayout('grid
                        ?items list(
                              list(hiCreateLabel(
                                      ?name 'enableLabel
                                      ?labelText "Enable")
                                       'row 0 'col 0)
    Recent versions of the tools (plus on support.cadence.com) have got better examples (I created a bunch of them) but of course they don't cover everything. Here's an example of a multi-line text field which stretches in both dimensions and the label stays where it is:
    hiCreateLayoutForm('ForumStretchLayout "Grid"
        ?items list(
          list(
            hiCreateLabel(
              ?name 'bigTextLabel
              ?labelText "<b>Big Text</b>"
            'row 0 'col 0 'vert_align 'top
          list(
            hiCreateMLTextField(
              ?name 'bigText
            'row 0 'col 1
          list('col_stretch 0 0)
          list('col_stretch 1 1)
          list('row_stretch 0 1)
      ?frame "My frame"
    hiDisplayForm(ForumStretchLayout)
