  3. Adding more functions on "lxHiMousePopUp"
  • Subscribers 152
  • Views 1395
JJAP
JJAP over 3 years ago
Good Day!
Can you help me on how to add more functions on "lxHiMousePopUp". This is when you right click on Layout Window and a pop up window will show up with list of functions (See image below).
James
  • psill00
    psill00 over 3 years ago +1
    If you have access to the source link library there is a good example on adding the popup guis Search for "How to create and add or insert a a custom menu item in the RMB context senseitive (as per selected…
  • psill00
    Search for "How to create and add or insert a a custom menu item in the RMB context senseitive (as per selected object) popup menu of layout or schematic?"
    https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1Od0000000nYIlEAM&pageName=ArticleContent
    Paul
  • JJAP
    JJAP over 3 years ago in reply to psill00
    Thanks Paul! This is helpful, I've implemented it on my custom RMB, it took me a while to figure it out but it was straight forward after that.
