  3. Complex mumber calculation
  • Views 10724
Martinsh
Martinsh over 3 years ago
Is there a sample way to do complex number calculation, such as complex number division, product, in Skill?
Martin
    Martin,
    If in Virtuoso, yes. ADE adds the support for complex numbers and overloads the maths operators to support these. You can use complex(0 1) to create (say) 0+1j or sqrt(-1). These are not supported in core SKILL, so they can't be used in PCells (I did implement a way of doing that for one customer a few years ago, but rather than sharing a lengthy solution for something you probably don't need and will get for free in Virtuoso, I'll keep it simple).
    Note, a little searching in cdnshelp for "complex" would have found this (e.g. enter "complex" in the box at the top of any help menu in Virtuoso). It's not on the first page of results, but you could have found it fairly easily.
  • Martinsh
    Martinsh over 3 years ago in reply to Andrew Beckett
    Thanks Andrew! I used it in the equation of design variables.
    Redards,
    Martin
