  3. How to preserve the termOrder in the CDF parameters and...
  • Views 10728
How to preserve the termOrder in the CDF parameters and the subckt in order in netlist when copying a schematic view
MFahmy
MFahmy over 3 years ago
I have noticed that when I create a netlist for a given schematic and then copy this schematic to a different library (no editing done) and netlist the copy I get different pin ordering in the pin list, and when looking in the CDF parameters termOrder I see they are different
- is there a way to preserver the termOrder when copying the schematic view
- if not, how can I read the term order of a given schematic and set it in the copy from SKILL
Here is a snippet of the code I used to reproduce the issue
envSetVal("spectre.envOpts" "setTopLevelAsSubckt" `boolean t)
simulator('spectre)
design(lib_orig cell_orig view_orig)
createNetlist()
let((cv cv_new)
cv_orig=dbOpenCellViewByType(lib_orig cell_orig view_orig "schematic" "r")
dbCopyCellView(cv_orig lib_new cell_new view_new nil nil t)
dbClose(cv_orig)
cv_new=dbOpenCellViewByType( lib_new cell_new view_new "schematic" "a")
schCheck(cv_new)
dbSave(cv_new)
dbClose(cv_new)
design(lib_new cell_new view_new)
createNetlist()
comparing the two resulting netlists, I see that the terminals' order is different, and comparing the termOrder in the CDF Editor for the two schematic views , I see it is also different
Virtuoso version ICADVM20.1-64b 05/11/2023
Sub-version ICADVM20.1-64b.500.28.EHF13629
Fahmy
    Fahmy,
    When you copied the schematic, did you also copy the cell data.dm at the same time? If not, the CDF won't have been copied and hence the termOrder won't have been preserved. You could copy the CDF separately via Tools→CDF→Copy
  • MFahmy
    MFahmy over 3 years ago in reply to Andrew Beckett
    I believe only the schematic was copied, as I used the dbCopyCellView(cv_orig lib_new cell_new view_new nil nil t) command
    maybe I am missing something obvious, but how can I copy the data.dm from my skill code along with the schematic
    Fahmy
    Andrew Beckett over 3 years ago in reply to MFahmy
    Fahmy,
    Rather than copying the entire data.dm (this is something that the library manager copy offers), you could just use cdfCopyCDF()
  • MFahmy
    Thanks, it worked, but I noticed that after I copy the cdf when doing the cell copy, if later in the flow a check and save (schCheck(), dbSave()) is done, the termOrder is rest , although nothing really has changed related to the pins and some times nothing at all, is this expected ? is there a way indicate that the termOrder does not need update after a schCheck, I am using cdfCopyCDF with "baseCellData"
    Fahmy
