  3. Identify Empty File in Skill
  • Views 9021
amaru
amaru over 3 years ago
Hi everyone,
I reading a file by following command:
while(gets(LinValue myFile)
;;; body
);while ends
When file is empty, I am getting following error :
*Error* range: argument #1 should be a number (type template = "n") - nil
*Error* load: error while loading file - "*string*"
I am checking the file with isFile(myFile), but my file exists but is empty. How can I check if file is empty using SKILL? or any other solution to this problem.
Thanks in advance
Amar
  • mschw
    mschw over 3 years ago
    Hi Amar,
    you can use the SKILL function fileLength to identify the number of bytes of a file.
    Matthias
  • mbracht
    mbracht over 3 years ago
    I do not get this error for an empty file, may I see the entire code please.
    Max
  • amaru
    amaru over 3 years ago in reply to mbracht
    Thank you Matthias and Max for your response.
    fileLength is exactly what I was looking for. Thank you Matthias.
    Max,
    After you pointed out, I again debugged the issue and found out that the error was not due to while(gets(... ...)).
    Actually there were some variables which needs to be assigned inside while loop and then following command was invoked ::
    geAddHilightLabel(evalstring(highlightID) X1:Y1 "someSignal" "centerCenter" "R0" "stick" 0.01 t)
    X1 and Y1 were nil because code didn't gone inside the loop, that is why the error was coming. I am sorry, I didn't looked carefully earlier.
    I was making a file through some linux functions and sometimes they can be empty isFIle(....) was not working for me. But now fileLength is working as expected.
    Thanks again
    Amar
