  3. How to use dbShapeQuery to get rect bbox from bottom to...
  • Views 9057
How to use dbShapeQuery to get rect bbox from bottom to top in mosaic type?
Charley Chen
Charley Chen over 3 years ago
Hi All,
dbShapeQuery can get shape box from bottom to top for instance well,but I have shape inside mosaic .
How to handle shape inside mosaic from bottom to top?
Thak you,
Charley
    Charley,
    I use a combination of dbGetHierPathTransform and abGetHierPathShape (unfortunately this function doesn't exist as a built-in):
    (defun abGetHierPathShape (overlap)
      (if (listp overlap)
        (abGetHierPathShape (cadr overlap))
        overlap))
    Then you can do (say):
    theShapes=dbShapeQuery(geGetEditCellView() list("Metal3" "drawing") enterBox()) ; use enterBox to define the rectangle for testing
    newShapes=foreach(mapcar obj theShapes dbCopyFig(abGetHierPathShape(obj) geGetEditCellView() dbGetHierPathTransform(obj)))
    newShapes~>layerName="Via1" ; just to make them stand out
  • Charley Chen
    Charley Chen over 3 years ago in reply to Andrew Beckett
    Hi Andrew ,
    Thanks for reply for solution.
    If i don't have the cellview's permission and  just get the bbox of the shape info bottom to top  , How to do it ?
    Charley
    Andrew Beckett over 3 years ago in reply to Charley Chen
    Rather than using dbCopyFig, you can use dbTransformBBox. For example:
    topBBoxes=foreach(mapcar obj theShapes dbTransformBBox(abGetHierPathShape(obj)~>bBox dbGetHierPathTransform(obj)))
  • Charley Chen
    Hi Andrew ,
    Thank you very much for that.
    Charley
