  3. If condition error
  • Subscribers 150
  • Views 8932
If condition error
dakuang01
dakuang01 over 3 years ago
I could use some help.
I copied a part of the skill codes I've been writing. Basically I'm trying to the short metal ends going beyond a via.
The problem is the following if condition doesn't give me true and I don't know the reason. The step result says the values are the same like in the image.
if(getX1(d~>bBox)==caar(d~>points)-d~>width/2.0 then ;vertical line
Could you give me some advice on this? getX1 is giving me X1 number of a bBox list((X1 Y1) (X2 Y2))
foreach(d l_lineOnTheVia
    if(d~>objType == "path" then
        l_points = d~>points
       ;numberp(getX1(d~>bBox))
       ;numberp(caar(d~>points)-d~>width/2.0)
           if(x_centerY-getY1(d~>bBox) <= getY2(d~>bBox)-x_centerY then
               l_replace = list(getX1(d~>points) getY1(a~>bBox))
              rplaca(nthcdr(sub1(1) l_points) l_replace)
              d~>points = l_points
           else
               l_replace = list(getX2(d~>points) getY2(a~>bBox))
               rplaca(nthcdr(sub1(d~>nPoints) l_points) l_replace)
);endif
);endif
);foreach
Jane
    Jane,
    This is almost certainly due to a floating point rounding error. You should (almost) never use == to compare floating point numbers, unless you can guarantee that they were created the same way. So for example, comparing two coordinates in the database is safe because they will have both been converted from the underlying database units (which are integer underneath) in the same way.
    In this case you are comparing:
    getX1(d~>bBox)
    to
    The first comes directly from the database, but the second does a maths operation on a database value which can certainly lead to a tiny numerical error.
    The correct way to compare numbers in this case would be to convert to database units and compare as integers. So to do this in your code somewhere:
    dbu=cv~>DBUPerUU
    and then have a function:
    procedure(CCFcompareCoord(val1 val2 dbu)
      round(val1*dbu)==round(val2*dbu)
    and do:
    if(CCFcompareCoord(getX1(d~>bBox) caar(d~>points)-d~>width/2.0 dbu) then
    The idea here is that you are finding the database unit size and converting the numbers to integer which can be safely compared. The database is really stored as integers so this is safe.
    The simpler (although not really the right solution) could be to use the nearlyEqual function instead - although this doesn't really account for using suitable tolerances for the database, it will probably work OK:
    if(nearlyEqual(getX1(d~>bBox) caar(d~>points)-d~>width/2.0) then
    Personally I'd compare the coordinates as integers.
  • dakuang01
    dakuang01 over 3 years ago in reply to Andrew Beckett
    Thank you very much. I never knew I shouldn't compare floating point numbers.
    And with the code you provided it works!
    Jane
    Andrew Beckett over 3 years ago in reply to dakuang01
    Hi Jane,
    Note that this is not specific to SKILL - it's a problem in any language that uses IEEE floating point representation. For example in Python:
    >>> 0.1*33==3.3
    False
    >>> 0.1*33-3.3
    4.440892098500626e-16
    Anyway, glad the code I provided helped!
  • dakuang01
    Oh I see. I've coded for over 10 years whenever needed and haven't run into this kind of errors. Glad now I know!
    Jane
