  3. devices() compilation error
  • Subscribers 150
  • Views 7760
FunnydoubleM
FunnydoubleM over 3 years ago
Hi, I'm using the function devices() to use the function leChopShape, and this error is reported.  Can the function starting with le be used in devices()?
 \o *WARNING* (DB-270001): Pcell evaluation for TECHLIB/nmos/layout has the following error(s):
\o *WARNING* (DB-270002): ("eval" 0 t nil ("*Error* eval: undefined function" leChopShape))
\o *WARNING* (DB-270003): Error kept in "errorDesc" property of the label "pcellEvalFailed" on layer/purpose "marker/error" in the submaster.
  • skillUser
    skillUser over 3 years ago
    No, you can't use functions that begin with the le prefix in a PCell.  The functions that can be used in a PCell start with these prefixes: tech, db, rod, dd, cdf, abe, cst, tx, some pc* functions and core SKILL functions. Check the documentation for the section called "Safety Rules for Creating SKILL Pcells" which will give more details.
    Best regards,
    Lawrence.
  • FunnydoubleM
    FunnydoubleM over 3 years ago in reply to skillUser
    Thank you for your reply, it has been very beneficial.
