  3. How to make the Option "Fig Groups" turn on when executing...
  • Views 3569
How to make the Option "Fig Groups" turn on when executing the Virtuoso Layout
Jinhyung
Jinhyung over 3 years ago
Thanks for your time.
I'm using the "Group" in the Virtuoso Layout, and always turn on these 2 options.
1. "Display Options" -> "Display Controls" -> "Group Name Only"
2. "Options" -> "Fig Groups" -> "Visible"
With turning on these options, I can see the group names only without seeing the every layer in the group when I press the key "Ctrl + F".
Now, I make the first option turn on automatically when I execute the Virtuoso with setting the Cdsenv Editor.
However, I can't find the way to turn on the second option above automatically, so I turn on this option whenever I execute the Virtuoso Layout.
Is there a method to turn on that second option automatically when executing the Virtuoso?
Best regards.
    After not understanding what you meant by "Options" -> "Fig Groups" -> "Visible", I eventually realised you must be talking about the "Objects" palette as part of the layer palette and controlling Fig Groups there (at least that's what I assume you meant).
    These two settings can be made by setting this in your .cdsinit (for example) or putting in a SKILL file and loading it with load("my options.il") :
    envSetVal("layout" "pteInfraDefValueObjGrids" 'string "Fig_Groups t")
    envSetVal("layout" "displayFigGroupName" 'boolean t)
  • Jinhyung
    Jinhyung over 3 years ago in reply to Andrew Beckett
    I apologize for my insufficient question.
    But, I got the perfect answer. I really appreciate it!
    Best ragards.
