  3. How to change the pin size to a metal using leSizeShape...
  • Subscribers 150
  • Views 7632
How to change the pin size to a metal using leSizeShape in skill layout
aj046499
aj046499 over 3 years ago
How to change the pin size to a metal using leSizeShape in skill layout? or may i get examples where leSizeShape is used.
    There's two examples in the documentation. What more do you need? It takes a shape object and then an amount to grow by (or shrink if negative) or a list of grow values if you want to grow by different amounts in each direction.
