  3. Could you please give me the procedure which returns the...
  • Views 10448
Could you please give me the procedure which returns the bbox of all selected shapes.
Arokia
Arokia over 3 years ago
Hi
Could anyone give me the procedure (function) which returns the bbox of all selected shapes.
BTW will the geGetObjectSelectedSet function work in this case?
Arokia Bharat
  • RobMan
    RobMan over 3 years ago
    This Article should help...
    How do I get the bounding box of all of the selected shapes? (cadence.com)
    I answered a very similar question in a post a year or so go.
    The geGetObjectSelectedSet() returns hierarchically selected objects - it's nothing to do with getting the bbox of selected shapes.
  • Arokia
    Arokia over 3 years ago in reply to Andrew Beckett
    Based on your previous program, the geGetSelSet()~>bBox statement helps extract the bBox of the selected object, but lets say I want to extract the Layer type, for example M1 drawing or M2 drawing. May I please know what "Statement" I can use? As I would like to use an IF statement to perform actions based on the type of Layer.
    Previous Program given to me a year back.
    procedure(CCFshowBBox(@key printIndividual printOverall (figs geGetSelSet()))
      when(figs
        destructuringBind(((ollx olly) (ourx oury)) car(figs)~>bBox
          foreach(fig figs
            when(printIndividual
              printf("Selected item bBox: %L\n" fig~>bBox)
            destructuringBind(((llx lly) (urx ury)) fig~>bBox
              ollx=min(ollx llx)
              olly=min(olly lly)
              ourx=max(ourx urx)
              oury=max(oury ury)
          when(printOverall
            printf("Overall bBox of selected objects: %L\n"
              list(ollx:olly ourx:oury))
    Arokia Bharat
  • Arokia
    Arokia over 3 years ago in reply to Arokia
    I tried a few things.
    On the CIW window I gave the statement geGetSelSet()~>?
    After doing this it showed a couple of properties identifiers.
    So I decided to grab the below.
    1. geGetSelSet()~>layerName
    For extracting the name of the layer property.
    2. geGetSelSet()~>purpose
    for extracting the layer purpose
    3. I guess height and width can be extracted from geGetSelSet()~>bBox
    But any short cut would be helpful.
    Andrew Beckett over 3 years ago in reply to Arokia
    Hi Arokia,
    It's not entirely obvious what it is you want to do, but you could use (say) inside the foreach loop:
    if(fig~>layerName=="M1" && fig~>purpose=="drawing" then
      ... do something...
    else
      ... do something else...
    I'd also not noticed that original question a year ago was essentially the same as this one. I found the original post but didn't notice it was also asked by you.
