  3. String expression evaluation
  • Views 9967
lordosGouv
lordosGouv over 3 years ago
I use the following functions to calculate the result of an expression that is saved in string format:
(lambda( (a b) evalstring( "a+2*b" ) ) 1 2)
is there any way to do the same thing when the parameters and their values are saved in lists whose length is not constant in runtime and variable names are saved as strings e.g.:
parameters = list("a" "b" "c" ...)
param_values = list(1 2 3 ...)
expression = "a+2*b+3*c+...."
Thank you in advance
    Andrew Beckett over 3 years ago +1
    Generally it's not the most efficient to do this kind of run-time evaluation, but if you can't avoid it (i.e. the expressions have to be in strings), you could could achieve it this way: procedure(CCFevalExprWithParameters…
    procedure(CCFevalExprWithParameters(expr paramNames paramValues)
      eval(
        `let(,foreach(mapcar (name value) paramNames paramValues
    	list(concat(name) value))
          evalstring(expr)
    Then you'd use:
    CCFevalExprWithParameters(expression parameters param_values)
    The idea is that it builds a let statement with name-value pairs according to the lists you provided, and evaluates the string within that context.
    Andrew Beckett over 3 years ago in reply to Andrew Beckett
    In fact, here's a small improvement which means it only does a single evaluation - instead of an eval with an evalstring inside, it uses the SKILL parser (using linereadstring) to parse the expression, but only calls the evaluator once.
      eval(
          ,@linereadstring(evalstring(expr))
  • lordosGouv
    lordosGouv over 3 years ago in reply to Andrew Beckett
    Thank you very much for your helpful and detailed response!!
