  3. SKILL syntax highlighting resource for Nedit
  • Views 9902
MomchilMilev
MomchilMilev over 3 years ago
Hi everyone,
looked for this to share with customer and not finding the (Linux) Nedit resource file for SKILL -
so posting it here !
Instructions:
copy/paste the following text into ~/.nedit/nedit.rc file under your Linux home
(note: replace the complete content of the file at once):
! Preferences file for NEdit
! (User settings in X "application defaults" format)
! This file is overwritten by the "Save Defaults..." command in NEdit
! and serves only the interactively settable options presented in the NEdit
! "Preferences" menu. To modify other options, such as key bindings, use
! the .Xdefaults file in your home directory (or the X resource
! specification method appropriate to your system). The contents of this
! file can be moved into an X resource file, but since resources in this file
! override their corresponding X resources, either this file should be
! deleted or individual resource lines in the file should be deleted for the
! moved lines to take effect.
nedit.fileVersion: 5.6
nedit.shellCommands: \
spell:Alt+B:s:ED:\n\
(cat;echo "") | spell\n\
wc::w:ED:\n\
wc | awk '{print $1 " lines, " $2 " words, " $3 " characters"}'\n\
sort::o:EX:\n\
sort\n\
number lines::n:AW:\n\
nl -ba\n\
make:Alt+Z:m:W:\n\
make\n\
expand::p:EX:\n\
expand\n\
unexpand::u:EX:\n\
unexpand\n
nedit.macroCommands: \
Complete Word:Alt+D::: {\n\
# This macro attempts to complete the current word by\n\
# finding another word in the same document that has\n\
# the same prefix; repeated invocations of the macro\n\
# (by repeated typing of its accelerator, say) cycles\n\
# through the alternatives found.\n\
# \n\
# Make sure $compWord contains something (a dummy index)\n\
$compWord[""] = ""\n\
\n\
# Test whether the rest of $compWord has been initialized:\n\
# this avoids having to initialize the global variable\n\
# $compWord in an external macro file\n\
if (!("wordEnd" in $compWord)) {\n\
# we need to initialize it\n\
$compWord["wordEnd"] = 0\n\
$compWord["repeat"] = 0\n\
$compWord["init"] = 0\n\
$compWord["wordStart"] = 0\n\
}\n\
\n\
if ($compWord["wordEnd"] == $cursor) {\n\
$compWord["repeat"] += 1\n\
}\n\
else {\n\
$compWord["repeat"] = 1\n\
$compWord["init"] = $cursor\n\
\n\
# search back to a word boundary to find the word to complete\n\
# (we use \\w here to allow for programming "words" that can include\n\
# digits and underscores; use \\l for letters only)\n\
$compWord["wordStart"] = search("<\\\\w+", $cursor, "backward", "regex", "wrap")\n\
\n\
if ($compWord["wordStart"] == -1)\n\
return\n\
\n\
if ($search_end == $cursor)\n\
$compWord["word"] = get_range($compWord["wordStart"], $cursor)\n\
else\n\
return\n\
}\n\
s = $cursor\n\
for (i=0; i <= $compWord["repeat"]; i++)\n\
s = search($compWord["word"], s - 1, "backward", "regex", "wrap")\n\
\n\
if (s == $compWord["wordStart"]) {\n\
beep()\n\
s = $compWord["wordStart"]\n\
se = $compWord["init"]\n\
}\n\
else\n\
se = search(">", s, "regex")\n\
\n\
replace_range($compWord["wordStart"], $cursor, get_range(s, se))\n\
\n\
$compWord["wordEnd"] = $cursor\n\
}\n\
Fill Sel. w/Char:::R: {\n\
# This macro replaces each character position in\n\
# the selection with the string typed into the dialog\n\
# it displays.\n\
if ($selection_start == -1) {\n\
beep()\n\
return\n\
}\n\
\n\
# Ask the user what character to fill with\n\
fillChar = string_dialog("Fill selection with what character?", \\\n\
"OK", "Cancel")\n\
if ($string_dialog_button == 2 || $string_dialog_button == 0)\n\
return\n\
\n\
# Count the number of lines (NL characters) in the selection\n\
# (by removing all non-NLs in selection and counting the remainder)\n\
nLines = length(replace_in_string(get_selection(), \\\n\
"^.*$", "", "regex"))\n\
\n\
rectangular = $selection_left != -1\n\
\n\
# work out the pieces of required of the replacement text\n\
# this will be top mid bot where top is empty or ends in NL,\n\
# mid is 0 or more lines of repeats ending with NL, and\n\
# bot is 0 or more repeats of the fillChar\n\
\n\
toplen = -1 # top piece by default empty (no NL)\n\
midlen = 0\n\
botlen = 0\n\
\n\
if (rectangular) {\n\
# just fill the rectangle: mid\\n \\ nLines\n\
# mid\\n /\n\
# bot - last line with no nl\n\
midlen = $selection_right - $selection_left\n\
botlen = $selection_right - $selection_left\n\
} else {\n\
# |col[0]\n\
# .........toptoptop\\n |col[0]\n\
# either midmidmidmidmidmid\\n \\ nLines - 1 or ...botbot...\n\
# midmidmidmidmidmid\\n / |col[1]\n\
# botbot... |\n\
# |col[1] |wrap margin\n\
# we need column positions col[0], col[1] of selection start and\n\
# end (use a loop and arrays to do the two positions)\n\
sel[0] = $selection_start\n\
sel[1] = $selection_end\n\
\n\
# col[0] = pos_to_column($selection_start)\n\
# col[1] = pos_to_column($selection_end)\n\
\n\
for (i = 0; i < 2; ++i) {\n\
end = sel[i]\n\
pos = search("^", end, "regex", "backward")\n\
thisCol = 0\n\
while (pos < end) {\n\
nexttab = search("\\t", pos)\n\
if (nexttab < 0 || nexttab >= end) {\n\
thisCol += end - pos # count remaining non-tabs\n\
nexttab = end\n\
} else {\n\
thisCol += nexttab - pos + $tab_dist\n\
thisCol -= (thisCol % $tab_dist)\n\
}\n\
pos = nexttab + 1 # skip past the tab or end\n\
}\n\
col[i] = thisCol\n\
}\n\
toplen = max($wrap_margin - col[0], 0)\n\
botlen = min(col[1], $wrap_margin)\n\
\n\
if (nLines == 0) {\n\
toplen = -1\n\
botlen = max(botlen - col[0], 0)\n\
} else {\n\
midlen = $wrap_margin\n\
if (toplen < 0)\n\
toplen = 0\n\
nLines-- # top piece will end in a NL\n\
}\n\
}\n\
\n\
# Create the fill text\n\
# which is the longest piece? make a line of that length\n\
# (use string doubling - this allows the piece to be\n\
# appended to double in size at each iteration)\n\
\n\
len = max(toplen, midlen, botlen)\n\
charlen = length(fillChar) # maybe more than one char given!\n\
\n\
line = ""\n\
while (len > 0) {\n\
if (len % 2)\n\
line = line fillChar\n\
len /= 2\n\
if (len > 0)\n\
fillChar = fillChar fillChar\n\
}\n\
# assemble our pieces\n\
toppiece = ""\n\
midpiece = ""\n\
botpiece = ""\n\
if (toplen >= 0)\n\
toppiece = substring(line, 0, toplen * charlen) "\\n"\n\
if (botlen > 0)\n\
botpiece = substring(line, 0, botlen * charlen)\n\
\n\
# assemble midpiece (use doubling again)\n\
line = substring(line, 0, midlen * charlen) "\\n"\n\
while (nLines > 0) {\n\
if (nLines % 2)\n\
midpiece = midpiece line\n\
nLines /= 2\n\
if (nLines > 0)\n\
line = line line\n\
}\n\
# Replace the selection with the complete fill text\n\
replace_selection(toppiece midpiece botpiece)\n\
}\n\
Quote Mail Reply:::: {\n\
if ($selection_start == -1)\n\
replace_all("^.*$", "\\\\> &", "regex")\n\
else\n\
replace_in_selection("^.*$", "\\\\> &", "regex")\n\
}\n\
Unquote Mail Reply:::: {\n\
replace_all("(^\\\\> )(.*)$", "\\\\2", "regex")\n\
else\n\
replace_in_selection("(^\\\\> )(.*)$", "\\\\2", "regex")\n\
}\n\
Comments>/* Comment */@C@C++@Java@CSS@JavaScript@Lex:::R: {\n\
selStart = $selection_start\n\
selEnd = $selection_end\n\
replace_range(selStart, selEnd, "/* " get_selection() " */")\n\
select(selStart, selEnd + 6)\n\
}\n\
Comments>/* Uncomment */@C@C++@Java@CSS@JavaScript@Lex:::R: {\n\
pos = search("(?n\\\\s*/\\\\*\\\\s*)", $selection_start, "regex")\n\
start = $search_end\n\
end = search("(?n\\\\*/\\\\s*)", $selection_end, "regex", "backward")\n\
if (pos != $selection_start || end == -1 )\n\
return\n\
replace_selection(get_range(start, end))\n\
select(pos, $cursor)\n\
}\n\
Comments>// Comment@C@C++@Java@JavaScript:::R: {\n\
replace_in_selection("^.*$", "// &", "regex")\n\
}\n\
Comments>// Uncomment@C@C++@Java@JavaScript:::R: {\n\
replace_in_selection("(^[ \\\\t]*// ?)(.*)$", "\\\\2", "regex")\n\
}\n\
Comments># Comment@Perl@Sh Ksh Bash@NEdit Macro@Makefile@Awk@Csh@Python@Tcl:::R: {\n\
replace_in_selection("^.*$", "#&", "regex")\n\
}\n\
Comments># Uncomment@Perl@Sh Ksh Bash@NEdit Macro@Makefile@Awk@Csh@Python@Tcl:::R: {\n\
replace_in_selection("(^[ \\\\t]*#)(.*)$", "\\\\2", "regex")\n\
}\n\
Comments>-- Comment@SQL:::R: {\n\
replace_in_selection("^.*$", "--&", "regex")\n\
}\n\
Comments>-- Uncomment@SQL:::R: {\n\
replace_in_selection("(^[ \\\\t]*--)(.*)$", "\\\\2", "regex")\n\
}\n\
Comments>! Comment@X Resources:::R: {\n\
replace_in_selection("^.*$", "!&", "regex")\n\
}\n\
Comments>! Uncomment@X Resources:::R: {\n\
replace_in_selection("(^[ \\\\t]*!)(.*)$", "\\\\2", "regex")\n\
}\n\
Comments>% Comment@LaTeX:::R: {\n\
replace_in_selection("^.*$", "%&", "regex")\n\
}\n\
Comments>% Uncomment@LaTeX:::R: {\n\
replace_in_selection("(^[ \\\\t]*%)(.*)$", "\\\\2", "regex")\n\
}\n\
Comments>Bar Comment@C:::R: {\n\
if ($selection_left != -1) {\n\
dialog("Selection must not be rectangular")\n\
return\n\
}\n\
start = $selection_start\n\
end = $selection_end-1\n\
origText = get_range($selection_start, $selection_end-1)\n\
newText = "/*\\n" replace_in_string(get_range(start, end), \\\n\
"^", " * ", "regex") "\\n */\\n"\n\
replace_selection(newText)\n\
select(start, start + length(newText))\n\
}\n\
Comments>Bar Uncomment@C:::R: {\n\
pos = search("/\\\\*\\\\s*\\\\n", selStart, "regex")\n\
if (pos != selStart) return\n\
end = search("\\\\n\\\\s*\\\\*/\\\\s*\\\\n?", selEnd, "regex", "backward")\n\
if (end == -1 || $search_end < selEnd) return\n\
newText = get_range(start, end)\n\
newText = replace_in_string(newText,"^ *\\\\* ?", "", "regex", "copy")\n\
if (get_range(selEnd, selEnd - 1) == "\\n") selEnd -= 1\n\
replace_range(selStart, selEnd, newText)\n\
select(selStart, selStart + length(newText))\n\
}\n\
Make C Prototypes@C@C++:::: {\n\
# simplistic extraction of C function prototypes, usually good enough\n\
start = 0\n\
end = $text_length\n\
} else {\n\
end = $selection_end\n\
}\n\
string = get_range(start, end)\n\
# remove all C++ and C comments, then all blank lines in the extracted range\n\
string = replace_in_string(string, "//.*$", "", "regex", "copy")\n\
string = replace_in_string(string, "(?n/\\\\*.*?\\\\*/)", "", "regex", "copy")\n\
string = replace_in_string(string, "^\\\\s*\\n", "", "regex", "copy")\n\
nDefs = 0\n\
searchPos = 0\n\
prototypes = ""\n\
staticPrototypes = ""\n\
for (;;) {\n\
headerStart = search_string(string, \\\n\
"^[a-zA-Z]([^;#\\"'{}=><!/]|\\n)*\\\\)[ \\t]*\\n?[ \\t]*\\\\{", \\\n\
searchPos, "regex")\n\
if (headerStart == -1)\n\
break\n\
headerEnd = search_string(string, ")", $search_end,"backward") + 1\n\
prototype = substring(string, headerStart, headerEnd) ";\\n"\n\
if (substring(string, headerStart, headerStart+6) == "static")\n\
staticPrototypes = staticPrototypes prototype\n\
else\n\
prototypes = prototypes prototype\n\
searchPos = headerEnd\n\
nDefs++\n\
}\n\
if (nDefs == 0) {\n\
dialog("No function declarations found")\n\
return\n\
}\n\
new()\n\
focus_window("last")\n\
replace_range(0, 0, prototypes staticPrototypes)\n\
}\n
nedit.bgMenuCommands: \
Undo:::: {\n\
undo()\n\
}\n\
Redo:::: {\n\
redo()\n\
}\n\
Cut:::R: {\n\
cut_clipboard()\n\
}\n\
Copy:::R: {\n\
copy_clipboard()\n\
}\n\
Paste:::: {\n\
paste_clipboard()\n\
}\n
nedit.highlightPatterns: Ada:Default\n\
Awk:Default\n\
C++:Default\n\
C:Default\n\
CSS:Default\n\
Csh:Default\n\
Fortran:Default\n\
Java:Default\n\
JavaScript:Default\n\
LaTeX:Default\n\
Lex:Default\n\
Makefile:Default\n\
Matlab:Default\n\
NEdit Macro:Default\n\
Pascal:Default\n\
Perl:Default\n\
PostScript:Default\n\
Python:Default\n\
Regex:Default\n\
SGML HTML:Default\n\
SQL:Default\n\
Sh Ksh Bash:Default\n\
Tcl:Default\n\
VHDL:Default\n\
Verilog:Default\n\
XML:Default\n\
X Resources:Default\n\
Skill:1:0{\n\
comment:"/\\*":"\\*/"::Comment::\n\
comment_Clike:"//":"$"::Comment::\n\
skill comment:";":"$"::Comment::\n\
string:"""":"""":"\\n":String::\n\
string escape chars:"\\\\(.|\\n)":::String:string:\n\
numeric constant:"<((0(x|X)[0-9a-fA-F]*)|(([0-9]+\\.?[0-9]*)|(\\.[0-9]+))((e|E)(\\+|-)?[0-9]+)?)(L|l|UL|ul|u|U|F|f)?>":::Preprocessor::D\n\
procedure calls:"<(procedure|return)\\(":::Plain::D\n\
procedure color:"\\1":""::Storage Type:procedure calls:DC\n\
control calls:"<(if|when|unless|cond|case|caseq|while|for|foreach)\\(":::Plain::D\n\
control color:"\\1":""::Subroutine:control calls:DC\n\
control then else:"<(then|else)>":::Subroutine::D\n\
function calls:"<([a-zA-Z][a-zA-Z0-9_?]*)\\(":::Plain::D\n\
function color:"\\1":""::Identifier1:function calls:DC\n\
braces:"[{}]":::Comment::D\n\
}\n\
CDS log:1:0{\n\
comment:"\\\\#.*$":::Comment::\n\
output:"\\\\o.*$":::Preprocessor::\n\
warning:"\\\\w.*$":::Warning::\n\
cmd_input:"\\\\a.*$":::Pointer::\n\
cmd_return:"\\\\r.*$":::LaTeX Math::\n\
timestamp:"^[0-9. :]+":::De-emphasized::\n\
prompt:"\\\\p":::Plain::\n\
nedit.languageModes: Ada:.ada .ad .ads .adb .a:::::::\n\
Awk:.awk:::::::\n\
C++:.cc .hh .C .H .i .cxx .hxx .cpp .c++::::::".,/\\`'!|@#%^&*()-=+{}[]"":;<>?~":\n\
C:.c .h::::::".,/\\`'!|@#%^&*()-=+{}[]"":;<>?~":\n\
CSS:css::Auto:None:::".,/\\`'!|@#%^&*()=+{}[]"":;<>?~":\n\
Csh:.csh .cshrc .tcshrc .login .logout:"^[ \\t]*#[ \\t]*![ \\t]*/bin/t?csh"::::::\n\
Fortran:.f .f77 .for:::::::\n\
Java:.java:::::::\n\
JavaScript:.js:::::::\n\
LaTeX:.tex .sty .cls .ltx .ins .clo .fd:::::::\n\
Lex:.lex:::::::\n\
Makefile:Makefile makefile .gmk:::None:8:8::\n\
Matlab:.m .oct .sci:::::::\n\
NEdit Macro:.nm .neditmacro:::::::\n\
Pascal:.pas .p .int:::::::\n\
Perl:.pl .pm .p5 .PL:"^[ \\t]*#[ \\t]*!.*perl":Auto:None:::".,/\\\\`'!$@#%^&*()-=+{}[]"":;<>?~|":\n\
PostScript:.ps .eps .epsf .epsi:"^%!":::::"/%(){}[]<>":\n\
Python:.py:"^#!.*python":Auto:None:::"!""#$%&'()*+,-./:;<=>?@[\\\\]^`{|}~":\n\
Regex:.reg .regex:"\\(\\?[:#=!iInN].+\\)":None:Continuous::::\n\
SGML HTML:.sgml .sgm .html .htm:"\\<[Hh][Tt][Mm][Ll]\\>"::::::\n\
SQL:.sql:::::::\n\
Sh Ksh Bash:.sh .bash .ksh .profile .bashrc .bash_logout .bash_login .bash_profile:"^[ \\t]*#[ \\t]*![ \\t]*/.*bin/(bash|ksh|sh|zsh)"::::::\n\
Tcl:.tcl .tk .itcl .itk::Smart:None::::\n\
VHDL:.vhd .vhdl .vdl:::::::\n\
Verilog:.v:::::::\n\
XML:.xml .xsl .dtd:"\\<(?i\\?xml|!doctype)"::None:::"<>/=""'()+*?|":\n\
X Resources:.Xresources .Xdefaults .nedit .pats nedit.rc:"^[!#].*([Aa]pp|[Xx]).*[Dd]efaults"::::::\n\
Yacc:.y::::::".,/\\`'!|@#%^&*()-=+{}[]"":;<>?~":\n\
Skill:.il .tf:::::::\n\
CDS log:.CDS.log .log:::None::::
nedit.styles: Plain:black:Plain\n\
Comment:gray20/gray:Italic\n\
Keyword:black:Bold\n\
Operator:dark blue:Bold\n\
Bracket:dark blue:Bold\n\
Storage Type:brown:Bold\n\
Storage Type1:saddle brown:Bold\n\
String:darkGreen:Plain\n\
String1:SeaGreen:Plain\n\
String2:darkGreen:Bold\n\
Preprocessor:RoyalBlue4:Plain\n\
Preprocessor1:blue:Plain\n\
Character Const:darkGreen:Plain\n\
Numeric Const:darkGreen:Plain\n\
Identifier:brown:Plain\n\
Identifier1:RoyalBlue4:Plain\n\
Identifier2:SteelBlue:Plain\n\
Subroutine:brown:Plain\n\
Subroutine1:chocolate:Plain\n\
Ada Attributes:plum:Bold\n\
Label:red:Italic\n\
Flag:red:Bold\n\
Text Comment:SteelBlue4:Italic\n\
Text Key:VioletRed4:Bold\n\
Text Key1:VioletRed4:Plain\n\
Text Arg:RoyalBlue4:Bold\n\
Text Arg1:SteelBlue4:Bold\n\
Text Arg2:RoyalBlue4:Plain\n\
Text Escape:gray30:Bold\n\
LaTeX Math:darkGreen:Plain\n\
Pointer:#660000:Bold\n\
Regex:#009944:Bold\n\
Warning:brown2:Italic\n\
De-emphasized:gray:Plain
nedit.smartIndentInit: C:Default\n\
C++:Default\n\
Python:Default\n\
Matlab:Default
nedit.smartIndentInitCommon: Default
nedit.autoWrap: Continuous
nedit.wrapMargin: 0
nedit.autoIndent: Auto
nedit.autoSave: True
nedit.openInTab: True
nedit.saveOldVersion: False
nedit.showMatching: Delimiter
nedit.matchSyntaxBased: True
nedit.highlightSyntax: True
nedit.backlightChars: False
nedit.searchDialogs: False
nedit.beepOnSearchWrap: False
nedit.retainSearchDialogs: False
nedit.searchWraps: True
nedit.stickyCaseSenseButton: True
nedit.repositionDialogs: True
nedit.autoScroll: False
nedit.appendLF: True
nedit.sortOpenPrevMenu: True
nedit.statisticsLine: False
nedit.iSearchLine: False
nedit.sortTabs: False
nedit.tabBar: True
nedit.tabBarHideOne: True
nedit.toolTips: True
nedit.globalTabNavigate: False
nedit.lineNumbers: False
nedit.pathInWindowsMenu: True
nedit.warnFileMods: True
nedit.warnRealFileMods: True
nedit.warnExit: True
nedit.searchMethod: Literal
nedit.textRows: 24
nedit.textCols: 80
nedit.tabDistance: 4
nedit.emulateTabs: 4
nedit.insertTabs: False
nedit.textFont: -*-courier-medium-r-normal--14-*-*-*-*-iso8859-1
nedit.boldHighlightFont: -*-courier-bold-r-normal--14-*-*-*-*-iso8859-1
nedit.italicHighlightFont: -*-courier-medium-o-normal--14-*-*-*-*-iso8859-1
nedit.boldItalicHighlightFont: -*-courier-bold-o-normal--14-*-*-*-*-iso8859-1
nedit.textFgColor: #141312
nedit.textBgColor: #e0dfde
nedit.selectFgColor: #ffffff
nedit.selectBgColor: #418bd4
nedit.hiliteFgColor: white
nedit.hiliteBgColor: red
nedit.lineNoFgColor: black
nedit.cursorFgColor: black
nedit.shell: /bin/csh
nedit.smartTags: True
nedit.prefFileRead: True
nedit.titleFormat: {%c} [%s] %f (%S) - %d
  • MomchilMilev
    Just to add - a somewhat simpler/different nedit.rc file is available for direct download under COS article:
    Article (11541560)
    Title: nedit configuration for SKILL programming language.
    URL: https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1Od0000000nZZjEAM&pageName=ArticleContent
    It does not include comment gray-out, but it could be another good start for your customization. Enjoy!
