  3. modelFile in Ocean script
  • Views 7821
DavidLou
DavidLou over 3 years ago
hello experts,
should be any easy question, in Ocean (or similar in Skill), modelFile() takes multiple strings as arguments to use different netlist or libraries. how can I make it more script friendly like variable concatenated lists?
    modelFilelist=list(list("path-to-lib1" "tt"));
     if(A then modelFilelist=cons(list("path-to-A-netlist" "") modelFilelist) );
     if(B then modelFilelist=cons(list("path-to-B-netlist" "") modelFilelist) );
    if(C then modelFilelist=cons(list("path-to-C-netlist" "") modelFilelist) );
    modelFile(modelFilelist);
it Nil-ed to execute the last line. it doesn't seem to take list of list as argument. how should I fix it or code it up?
thanks a lot,
David
    David,
    You could do this:
    apply('modelFile modeiFilelist)
    which will (I think) do what you want.
  • DavidLou
    DavidLou over 3 years ago in reply to Andrew Beckett
    Works perfectly. thanks Andrew.
